info
    DVDFab (UI/General) info
    How can you extract from:
    Dolby Digital Plus Audio Italian 1024 kbps 7.1 / 48 kHz / 1024 kbps to AC3 Core: 5.1 / 48 kHz / 576 kbps ( Core: 5.1 / 48 kHz / 576 kbps))
    Dolby Digital Plus Audio Italian 896 kbps 7.1 / 48 kHz / 896 kbps to AC3 Core: 5.1 / 48 kHz / 512 kbps ( Core: 5.1 / 48 kHz / 512 kbps))
    This is not a feature request, so you posted in the wrong place again. Please review how the forum is organized.
    Do you mean in Copy mode or Ripper mode? When you say “extract” do you mean Remove the audio stream or convert the audio stream from DD to AC-3 core?
      my mistake, I apologize
        however, as with dts hd but or TrueHD, from which dts or embedded ac3 can exit. In this case, two cores, 512 and 576, can exit from the two e-ac3 7.1s. Maybe you could enter this capacity directly during the reception of the disk for when using the ripper profile. thanks
          From a TrueHD of any type can be converted to an E-AC3 7.1 1536 mhz?
