Disney's little MP3 player is cheap, appealing to children, and difficult to find software for. A DVD to mixmax file would be an excellent addition to the best video software out there. The web is full of requests for a program that can convert to this format.
DVD to Disney Mix Max
I actually have one of these devices and have done some experimenting with it. Haven't gotten really good results, but then the movie that came with it has pretty poor playback characteristics too. I got 3 of them really cheap (woot.com) and gave two of them to my nieces. I'll see if I can find the test profile I was using.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
DVDFab should be able to convert movies for this with some tweaks to one of the profiles. I found mine, will see what works.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
The Mix Max is a picky device. I am experimenting. FYI the Disney Mix Central online store closed on 8/1/2010. They are sorry for the inconvenience.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
The digital copies that come with the MixMax are not readable by MediaInfo. Or VLC. Some kind of wierd format (.smv) for which there are several conflicting specs on the internet. It rejects wmv files made to the exact specs in the owner's manual.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
I have tamed the Mix Max devil and have just posted a profile for it in the New Profiles thread in DVD to Mobile. You can find it here:
Some of the Disney movie cards for this are selling for $50 each on amazon (now that Disney has stopped support). Make a few with this profile and DVDFab has paid for itself.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Hi Signals,
Thanks for the profile, it will be included in next version.
Best Regards,
FengtaoDVDFab is the all-in-one software package for copying Blu-ray/DVD and converting video file.
http://www.dvdfab.cn
- Benjamin Franklin 1706-1790
