did you know that your licenses can't be used any more, when you replace your old PCs by new ones.
Normal users do this every few years - which sense does a lifetime subscription make?
See my DVDfab mail thread below.
Best Regards
Marc
__________________________________________________ ______________
My first question to support:
I'm thinking about purchase of Passkey.
As I read I can install it on two machines.
I frequently change my computers (about every 6 months) and frequently reinstall Windows 7.
How to make sure that I do not run out of licenses (as happend with software from other vendors)?
First answer from Support:
Please understand that if you have bought the Single-User License, you can use it on two machines. That means you can install and register DVDFab on two computers at most.
If you want to register on the third computer, you need to purchase another license at .
My second question to support:
thanks for your answer, but this sounds like bad news...
Did I get you right:
When I buy your product, install it on both of my computers and sell them
6 months later (after deleting the harddisks) in order to get the latest
machines (which is likely), I will have to purchase your product again
paying the full price???
Or is it like e.g. Adobe Photoshop, where I can explicitly decrement the
license counter by using a deregistration tool when updating the PC?
Second Answer from Support:
Please understand that if you buy the Single-User License and had installed it on two machines, you can not use it any more. Because the Single-User License just can be used on two machines.
Best Regards
Marc
