This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
I've seen several responses posted that recommend disabling PathPlayer. Exactly what does that program do? My DVDFab program had it enabled. I changed it to only open if needed but I have no idea what it is for.
Thanks,
Ken
As the name suggests it is the artificial intelligence built into the program that selects the playable path on the DVD from the other stuff studios put on there to foil copy programs.
We recommend the default setting: Always Enable PathPlayer
On the somewhat rare occasion when the disc fails to be read properly, then disable PP for that particular disc (generally an older flick).
The setting "Enable PathPlayer when necessary" has been problematic in the past for some which is why we don't recommend it.
Btw, this was once the default setting...
Long time user, Lifetime member, On the question of Pathplayer, having the choice of enable when necessary has been a problem, then why the choice ? I personally have never had a problem with it. mine has always been on the selection of when necessary, and I only change it when there seems to be a problem and that seems to only happen when a new DVD comes out with something new on it.. But DVDfab is one of the Best Software on the market and has the Best Support teams out there.. Thanks for everything the you all do !!
The "when necessary" option is there because, when PathPlayer was first introduced, it caused a substantial increase in the time required to analyze and open a disc, but was still needed for many titles. Improvements since then have reduced the scan time, but the three options have remained. It is now needed for almost all discs, hence the recommendation (and default setting) to leave it Always Enabled. It also must be enabled to use the disc navigation options (jump to menu or movie) and to make sure the titles are displayed in playback order.
Just recently I've had problems with two older discs, one just today in fact, that appeared to have only two very small files on the dvd. A total of about 13mb.. for the life of me I couldn't figure it out! wound up using old DVD Decrypter to make backup's.
Reading this thread I went back and disabled PathPlayer and lo and behold there was the full disc showing up. So it just goes to show it sometimes pays to read through some threads, it can kickstart the brain and make a difference..
Hope this helps others..
This problem with older discs is a temporary bug that will be corrected. You will have fewer problems overall if you leave PathPlayer in the "Always Enable" mode and change it only when necessary for testing.
Signals, I cannot say that I hold much faith in the above statement.
This has been occurring since Pathplayer was introduced and I cannot see it changing.
I hope that you prove me wrong.
It is specific to DVDs, it operates in Copy and Ripper. As 90312 advised, turn it on and leave it on for optimum performance.
This is an old thread which contains dated information and will be closed. If you have additional questions, please start a new thread (topic) in this or another appropriate forum.
