Installing issue?
    Hi rtbe25,
    Could you please try DVDFab v8083 to see the result?
    Thanks.
    Best Regards,
    Fengtao
    http://www.dvdfab.cn
      Hi All:
      Thanks for you info and suggestion, fengtao have created a new thread for tracking this crash issue.
      Please downlaod the 8083 Debug version and post your log:
      Thanks in advanced.
      Potti
        I think I should mention this;-
        Last week I updated ADOBE READER to v10, and this week I noticed several programs were very slow opening up, including DVDFab 8, I also had problems with Int Exp 8 crashing frequently.
        After uninstalling Adobe Reader 10 & putting v9.4.2. back all the problems mentioned disappeared.
        My OS is vista 32bit Home Premium, this info might be useful to other memebers having similar problems.
        PS, someone mentioned Adobe in their post
          Please use the new thread so all the reports and logs will be in one place, it will make for a faster solution.
