HI there. I just downloaded the latest version of the software to try. I"ve been doing this every couple months to see if the blu ray rip will ever work and to this point it has not. Someday I'd like to get the software but until it works, obviously not worth the money. I"m trying to convert the blus using the standard iPad profile Mp4 and my computer freezes every time for any disc. Not sure what to do. Hardware is core i5 760, ATI Radeon HD 5870, 8GB RAM, Windows 7 Pro 32 bit, Asus P7P55D-E PRO. Help? Thanks.
COmputer freezes during conversion for any blu ray.
Hi fuzzyreets
If you would post your logs we may be able to help, if not it will all be guess work, and you may never get you issues straightened out.
The default location is:
Please use attachment button and attach your most recent, Internal and Burn log(s) and post right here.
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
DVDFab 8.0.8.5 (2011/03/26 14:11:38)
[code]DVDFab 8.0.8.5 (2011/03/26 14:23:11)
0m 00.65s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
0m 06.41s: detected blu-ray
0m 06.41s: drive L
0m 06.41s: blu-ray type 1
0m 06.41s: volume label GIRL_NEXT_DOOR
0m 10.74s: root 8CBBE7093C9B3463_VOLUME_SET_ID:GIRL_NEXT_DOOR:GIRL _NEXT_DOOR:GIRL_NEXT_DOOR
0m 12.02s: aacs 1 bd+ 1
0m 18.50s: got discinfo
0m 18.61s: got bdmv
0m 18.62s: got agid 0
0m 19.68s: sent host cert chal
0m 19.70s: got drive cert chal
0m 19.70s: BEC 0
0m 19.70s: DRIVE_VENDOR 0x0128
0m 21.32s: got drive key
0m 21.60s: got host key signature
0m 21.60s: verified drive signature
0m 21.60s: verified host signature
0m 23.38s: sent host signature and key point
0m 23.38s: got bus key
0m 23.38s: got volume id
0m 23.38s: got volume id mac
0m 23.38s: volume id is correct
0m 23.41s: got vid
0m 23.49s: blu-ray A1755C1CAF46DC0F0AFA025EBF26EFD2971517A6
0m 29.98s: got vuk
0m 29.98s: got fut
0m 30.24s: got unit key 1
0m 58.26s: got extended bdinfo
0m 58.26s: opened blu-ray
3m 34.72s:
3m 34.72s: create config(5)
3m 34.72s: convert profile(ipad.mp4)
3m 34.73s: blu-ray playlist(1) angle(0) chapter(1->29)
3m 34.73s: stream(4113,AVC,1) stream(4352,DTS-HD MA,1)
3m 34.75s: not set correct fourcc for video(28)
3m 34.76s: info: set output video frame_rate(24000/1001)
3m 34.81s: processing source(00073.m2ts)
3m 34.81s: try to use gpu acceleration(2) for video decoding
3m 34.81s: DXVA GPU acceleration for video decoding enabled
3m 35.87s: h264_encode: encode param profile(1) level(31) bitrate(1147)
DVDFab 8.0.8.5 (2011/03/26 15:21:28)
0m 00.39s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
0m 02.37s: detected blu-ray
0m 02.37s: drive L
0m 02.37s: blu-ray type 1
0m 02.37s: volume label GIRL_NEXT_DOOR
0m 03.30s: root 8CBBE7093C9B3463_VOLUME_SET_ID:GIRL_NEXT_DOOR:GIRL _NEXT_DOOR:GIRL_NEXT_DOOR
0m 04.60s: aacs 1 bd+ 1
0m 04.66s: got discinfo
DVDFab 8.0.8.5 (2011/03/26 15:21:55)
0m 00.23s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
0m 02.15s: detected blu-ray
0m 02.15s: drive L
0m 02.15s: blu-ray type 1
0m 02.16s: volume label GIRL_NEXT_DOOR
0m 02.82s: root 8CBBE7093C9B3463_VOLUME_SET_ID:GIRL_NEXT_DOOR:GIRL _NEXT_DOOR:GIRL_NEXT_DOOR
0m 04.11s: aacs 1 bd+ 1
0m 10.48s: got discinfo
0m 10.59s: got bdmv
0m 10.59s: got agid 0
0m 11.66s: sent host cert chal
0m 11.66s: got drive cert chal
0m 11.66s: BEC 0
0m 11.66s: DRIVE_VENDOR 0x0128
0m 13.29s: got drive key
0m 13.54s: got host key signature
0m 13.54s: verified drive signature
0m 13.54s: verified host signature
0m 15.33s: sent host signature and key point
0m 15.33s: got bus key
0m 15.33s: got volume id
0m 15.33s: got volume id mac
0m 15.33s: volume id is correct
0m 15.35s: got vid
0m 15.42s: blu-ray A1755C1CAF46DC0F0AFA025EBF26EFD2971517A6
0m 21.93s: got vuk
0m 21.93s: got fut
0m 22.18s: got unit key 1
0m 50.18s: got extended bdinfo
0m 50.18s: opened blu-ray
1m 51.02s:
1m 51.02s: create config(5)
1m 51.02s: convert profile(ipad.mp4)
1m 51.02s: blu-ray playlist(1) angle(0) chapter(1->29)
1m 51.02s: stream(4113,AVC,1) stream(4352,DTS-HD MA,1)
1m 51.04s: not set correct fourcc for video(28)
1m 51.04s: info: set output video frame_rate(24000/1001)
1m 51.07s: processing source(00073.m2ts)
1m 51.07s: using software decoder(h264 multi-thread)
1m 52.10s: h264_encode: encode param profile(1) level(31) bitrate(1658)
DVDFab 8.0.8.5 (2011/03/26 15:48:55)
0m 00.93s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
0m 04.02s: detected blu-ray
0m 04.02s: drive L
0m 04.02s: blu-ray type 1
0m 04.02s: volume label GIRL_NEXT_DOOR
0m 04.99s: root 8CBBE7093C9B3463_VOLUME_SET_ID:GIRL_NEXT_DOOR:GIRL _NEXT_DOOR:GIRL_NEXT_DOOR
0m 06.27s: aacs 1 bd+ 1
0m 12.52s: got discinfo
0m 12.63s: got bdmv
0m 12.63s: got agid 0
0m 13.71s: sent host cert chal
0m 13.71s: got drive cert chal
0m 13.71s: BEC 0
0m 13.71s: DRIVE_VENDOR 0x0128
0m 15.35s: got drive key
0m 15.58s: got host key signature
0m 15.58s: verified drive signature
0m 15.58s: verified host signature
0m 17.36s: sent host signature and key point
0m 17.36s: got bus key
0m 17.36s: got volume id
0m 17.36s: got volume id mac
0m 17.36s: volume id is correct
0m 17.36s: got vid
0m 17.45s: blu-ray A1755C1CAF46DC0F0AFA025EBF26EFD2971517A6
0m 23.85s: got vuk
0m 23.85s: got fut
0m 24.08s: got unit key 1
0m 51.59s: got extended bdinfo
0m 51.59s: opened blu-ray
DVDFab 8.0.8.5 (2011/03/26 15:51:05)
0m 02.24s: detected blu-ray
0m 02.24s: drive L
0m 02.26s: blu-ray type 1
0m 02.26s: volume label GIRL_NEXT_DOOR
0m 02.97s: root 8CBBE7093C9B3463_VOLUME_SET_ID:GIRL_NEXT_DOOR:GIRL _NEXT_DOOR:GIRL_NEXT_DOOR
0m 04.33s: aacs 1 bd+ 1
0m 10.71s: got discinfo
0m 10.82s: got bdmv
0m 10.84s: got agid 0
0m 11.90s: sent host cert chal
0m 11.91s: got drive cert chal
0m 11.91s: BEC 0
0m 11.91s: DRIVE_VENDOR 0x0128
0m 13.60s: got drive key
0m 13.85s: got host key signature
0m 13.85s: verified drive signature
0m 13.85s: verified host signature
0m 15.74s: sent host signature and key point
0m 15.74s: got bus key
0m 15.74s: got volume id
0m 15.74s: got volume id mac
0m 15.74s: volume id is correct
0m 15.75s: got vid
0m 15.85s: blu-ray A1755C1CAF46DC0F0AFA025EBF26EFD2971517A6
0m 22.30s: got vuk
0m 22.30s: got fut
0m 22.57s: got unit key 1
0m 50.27s: got extended bdinfo
0m 50.27s: opened blu-ray
1m 08.98s:
1m 08.98s: create config(5)
1m 08.98s: convert profile(ipad.mp4)
1m 08.98s: blu-ray playlist(1) angle(0) chapter(1->29)
1m 08.98s: stream(4113,AVC,1) stream(4352,DTS-HD MA,1)
1m 08.99s: not set correct fourcc for video(28)
1m 08.99s: info: set output video frame_rate(24000/1001)
1m 09.06s: processing source(00073.m2ts)
1m 09.06s: using software decoder(h264 multi-thread)
1m 10.12s: h264_encode: encode param profile(1) level(31) bitrate(2062)
56m 20.15s:
------ finish mobile work ------
DVDFab 8.0.8.5 (2011/03/26 17:26:23)
0m 00.51s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
0m 04.27s: detected blu-ray
0m 04.27s: drive L
0m 04.27s: blu-ray type 1
0m 04.27s: volume label ROUNDERS
0m 04.99s: root 03A1E25A ROUNDERS:ROUNDERS:ROUNDERS:ROUNDERS
0m 05.30s: aacs 1 bd+ 0
0m 05.39s: got discinfo
0m 05.41s: got bdmv
0m 05.41s: got agid 0
0m 06.49s: sent host cert chal
0m 06.49s: got drive cert chal
0m 06.49s: BEC 0
0m 06.49s: DRIVE_VENDOR 0x0128
0m 08.12s: got drive key
0m 08.37s: got host key signature
0m 08.37s: verified drive signature
0m 08.37s: verified host signature
0m 10.20s: sent host signature and key point
0m 10.20s: got bus key
0m 10.20s: got volume id
0m 10.20s: got volume id mac
0m 10.20s: volume id is correct
0m 10.20s: got vid
0m 10.28s: blu-ray 92B12E5564D3E076792D65D71AF59C4B72C0BC11
0m 10.71s: D 41350C86
0m 10.71s: got vuk
0m 10.76s: got unit key 1
Hi fuzzyreets
Make sure you set all options to software, to do this Open Fab click the Click the Green √ at top right corner of the DVDFab screen, and open Common Settings > General >A/V Codec, set Video Decoders to Software and set Video Encoder to Software also try unticking Enable Lightning Re-Coding restart Fab and try again.
Hope this helps
fuzzyreets
Try the iPhone4-1080 profile instead and see if it freezes. I use this one almost daily and it works fine for me. It should play on the iPad also I think.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Hi fuzzyreets
Are you also converting from the drive? If so do not do this.
Save the movie as main movie or full disc, depending on what you want too your hard drive.
Then reopen Fab and use the rip you just did as your source, choose options such as audio, subtitles, etc. and then do your converting from the rip you have on your hard drive and never from the drive.
Hope this helps
CBR929
CBR929
I'm thinking maybe it has something to do with the supported video codecs? Here is my laptop codec information:
Graphics Chipset :
Intel(R) HD Graphics
Supported Video Codecs :
DXVA_MODE_MPEG2
CoreAVC : cannot be detected.
Here is my main PC codec info:
DXVA_MODE_H264
DXVA_MODE_VC1
CoreAVC: cannot be detectec.
not sure if that means anything.....
Originally posted by fuzzyreets View PostI'm thinking maybe it has something to do with the supported video codecs? Here is my laptop codec information:
Graphics Chipset :
DXVA_MODE_MPEG2
DXVA_MODE_H264
DXVA_MODE_VC1
This is why I suggested setting to all Software, because you have an ATI Radeon HD 5870 which does not support Cuda, only NVidia cards do.
Fab uses the Cuda technology to take some of the load off your CPU so it does not have to work so hard. And ripping to your HDD first is the recommended procedure so as to save wear and tear on your drive.
CBR929
Originally posted by fuzzyreets View PostThanks for the above suggestions. I will try them out. To update, I was able to rip all those movies on my laptop using the same settings so I'm not sure what DVDFab doesn't like in my main computer but that seems to be the problem. I'll update tomorrow. Thanks again.
Do you have any way of monitoring your computers temps???
Also are the specs you gave in post #1 your main computer???
Originally posted by CBR929 View PostYou say that Fab worked in your laptop but not your main computer!!!
CBR929
Hadn't thought about temps. Good program to monitor that? I'm not over clocked or anything like that.
Yes specs in post 1 are from main computer. Thanks.
I would recommend speed fan http://www.softpedia.com/get/System/...SpeedFan.shtml
