I keep getting this message when I try to burn a DVD=
Failure to Burn, Task=2 Error=116[]
My dvd only burns about 45%, sometimes less. What does this mean, and how do I correct it? I have ruined several dvds, and do not want to ruin anymore. I realize from all the other messages, in regards to burning issues, that I should use a certain type of Verbatim. I have used memorex for ages, and have never had a problem before. I am using a new external burner, and I have to say it's burned fine before now. I have had my PC formatted recently, so maybe that's the problem. Do I need any special codecs with DVDFab, as I had some on my PC before it crashed. I did unplug my burner, then powered down my pc all the way, then connected the burner to the pc, once more, and powered it up. When I go into properties it says that it's working properly, so I don't really think my burner is the issue here. Any, or all help would be appreciated. Thank you
