VTS to mpeg
    Other VTS to mpeg
    Not sure if this will get deleated but kinda of has to dvdfab. When I make backups of my dvd's using dvdfab it makes vts files, is there any way to make it a mpeg file or is there a program that will join the files and make one big mpeg, it for the ease of use, my wife has no patients to make a few extra clicks or search a bit.
    Yeah, use the "DVD Ripper" module of Fab. See my "Best Practice" thread in my signature.
      You can also make image (ISO) files instead of VIDEO_TS folders. It only takes a few minutes more and they are single files that are easy to search for and play. They maintain the same quality as the original if you set DVDFab for DVD-9 size output. You may need to use DVDFab Virtual Drive (free) if your player software won't play images directly.
        Or she can click the VIDEO_TS.IFO and the movie will play through.
          From what he says, it takes too many clicks to get to it.
            ok I guess I misunderstood. I would install VLC media player, copy the movie folder to the desktop. One double click on the folder will play the movie through. Actually it's a single right click and then play with VLC.
              I used to use a program that would backup to .vob files and worked great but playibility was hit or miss, with dvdfab sucess rate has come to 94% but the output file is not one that can be easily shared between platforms, like a mpeg or mkv file. Maybe im missing something, (wish i was missing a wife now) but she likes to click on a title and done, many dvd structures do not play in order if they play at all. I use vob2.... which has worked great. Thanks to all that responded!!!!!!!!!
              I have vlc player installed , but my wd live box has issues with .ts files, works well most of the time with mpegs
                You can use VOB Passthrough in DVD Ripper to make one big VOB file of the DVD VOBs, but they won't have subtitles or other DVD-like features. You can change the file suffix of these to .mpg and most anything that can decode MPEG-2 will play them. An ISO (image) file still seems like it would really be the way to go. A single file that would play with at most a double-click in most cases. Don't know if the WD box will play them though. It probably would play the VOB Passthrough VOB/MPG files though.
                  Thanks admin I think you gave me the answer I was seeking, and thanks to all who tried to help.
