I installed 8.1.1.6 Beta and DVDFab crashed. It simply went through the normal startup. It scanned the disc. Then scan bar went away and DVDFab simply shut off. I tried 3 different DVD's with 2 different burner drives. I re-installed 8.1.1.2 and DVDFab is working fine.
8.1.1.6 Problem
Look at my signature below. Post logs!!!!sigpic
Sorry, my bad
Code:DVDFab 8.1.1.6 (2011/09/04 11:08:49) 0m 02.98s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:16:56) 0m 01.23s: Qt Translator file load success 0m 01.65s: option dvd2dvd 1 dvd2mobile 0 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 0 0m 06.76s: detected dvd 0m 06.79s: drive G 0m 06.79s: dvd type 1 0m 06.79s: volume label UNKNOWN 0m 06.90s: got copyright 1 fe 0m 07.10s: got udf/iso 0m 08.20s: got discinfo 0m 08.20s: pathplayer enabled 0m 18.53s: got dvdinfo 0m 18.68s: opened dvd DVDFab 8.1.1.6 (2011/09/04 12:17:39) 0m 01.21s: Qt Translator file load success 0m 01.26s: option dvd2dvd 1 dvd2mobile 0 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 0 0m 05.54s: detected dvd 0m 05.57s: drive G 0m 05.57s: dvd type 1 0m 05.59s: volume label UNKNOWN 0m 05.62s: got copyright 1 fe 0m 05.89s: got udf/iso 0m 06.86s: got discinfo 0m 06.86s: pathplayer enabled 0m 17.37s: got dvdinfo 0m 17.51s: opened dvd DVDFab 8.1.1.6 (2011/09/04 12:18:37) 0m 01.23s: Qt Translator file load success 0m 01.28s: option dvd2dvd 1 dvd2mobile 0 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 0 0m 03.15s: detected dvd 0m 03.20s: drive G 0m 03.20s: dvd type 1 0m 03.20s: volume label DRIVE_ANGRY 0m 03.39s: got copyright 1 fe 0m 03.71s: got udf/iso 0m 04.90s: got discinfo 0m 04.90s: pathplayer enabled 0m 23.01s: got dvdinfo 0m 23.17s: opened dvd DVDFab 8.1.1.6 (2011/09/04 12:22:34) 0m 01.23s: Qt Translator file load success 0m 01.29s: option dvd2dvd 1 dvd2mobile 0 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 0 0m 03.21s: detected dvd 0m 03.26s: drive G 0m 03.26s: dvd type 1 0m 03.26s: volume label VOYAGE_OF_THE_DAWN_TREADER 0m 03.43s: got copyright 1 fe 0m 03.76s: got udf/iso 0m 05.26s: got discinfo 0m 05.26s: pathplayer enabled 0m 22.95s: got dvdinfo 0m 23.20s: opened dvd DVDFab 8.1.1.6 (2011/09/04 12:23:27) 0m 01.21s: Qt Translator file load success 0m 01.26s: option dvd2dvd 1 dvd2mobile 0 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 0 0m 05.03s: detected dvd 0m 05.07s: drive F 0m 05.07s: dvd type 1 0m 05.07s: volume label VOYAGE_OF_THE_DAWN_TREADER 0m 05.26s: got copyright 1 fe 0m 05.60s: got udf/iso 0m 07.15s: got discinfo 0m 07.15s: pathplayer enabled 0m 25.51s: got dvdinfo 0m 25.70s: opened dvd DVDFab 8.1.1.6 (2011/09/04 12:24:04) 0m 01.20s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:06) 0m 01.18s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:08) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:09) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:11) 0m 01.18s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:12) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:14) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:16) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:17) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:19) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:20) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:22) 0m 01.18s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:23) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:25) 0m 01.18s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:27) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:28) 0m 01.17s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:30) 0m 01.18s: Qt Translator file load success DVDFab 8.1.1.6 (2011/09/04 12:24:31) 0m 01.17s: Qt Translator file load success
Bynal
What is your operating system?Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Check "common settings"/"subpicture" if the "Do not preselect a subpicture track" box is ticked, untick it and give it a try.How to post the internal log
Originally posted by 90312 View PostCheck "common settings"/"subpicture" if the "Do not preselect a subpicture track" box is ticked, untick it and give it a try.
I'm going to wait until there is a new update and see what happens then.
Originally posted by Bynal View PostLike I said, I reverted to 8.1.1.2 and it was fine. In fact I failed to mention that DVDFab worked great with 8.1.1.5 which means the "subpicture track box" wouldn't be an issue.
I'm going to wait until there is a new update and see what happens then.How to post the internal log
It's a minor bug and I'm sure the Devs have taken note of it.How to post the internal log
They have noticed the reports in this thread and tried to duplicate it without success. I will try it also with v8.1.1.6.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Really? Well oddly enough 8.1.1.7 does not exhibit the “bug†behavior. You can now tick the “Do not preselect any subpicture track†box.How to post the internal log
