loadlibrary failed with error 126
    loadlibrary failed with error 126. The specific module could not found.
    I am getting this error now...
    We need more info. When does it happen? Any other error codes or messages? What is your OS?
      That is the only error code when I start up the program... then it asks if I want to restart the program... if yes then it loops with the same error etc.
      OS is Windows7 32bit. i5 Intel w/8GB Mem ati5760 1TB WD Black HDD.
        If you haven't already, I'd update your video driver.
        What's your gpu?
          Please uninstall and reinstall DVDFab and have a try!
            Why are you running Windows 7 32 bit with 8GB's of memory?
            You need Windows 7 64 bit.
