Video quality vs. Audio quality
    How much difference would I hear by removing the HD Audio? How much difference between 100% & 90% Video quality?
    Here are my choices to make this fit on a 25GB disc.
    A) 100% Video quality with HD Audio removed
    B) 90% Video quality & keep the HD Audio
    Which would you opt for? Would it depend on the movie? A couple things to keep in mind. I love the video quality of Blu-Rays. Blows me away! When it comes to music quality I always go for the best quality mp3's. The lower bit rates actually hurt my ears. Having been a Sheetmetal worker for over 25 years has done quite a bit of damage to my hearing.
    Just trying to get a feel for what I'm actually losing with the choice I make. Thanks in advance for any input.
    This is very subjective and really depends on what kind of audio setup you have on your blu-ray player.
    If you have the blu-ray audio going through your TV, probably not to much difference.
    Having said that, the best bet is to back-up a disk without the HD audio and listen to it.
      Oh, I should have added that I guess. My audio is setup to run through an AVR with 5.1 speakers.
        Keep your HD audio if you like it, you'll never see the difference.
          If you are over age 30 and more or less satisfied with MP3 audio, you will never hear the difference
