1TB to 2TB HDD?
    Other Hardware 1TB to 2TB HDD?
    I copy many Blu-ray movies. I want to try storing to a large HDD & copy to disc when needed. Please, add experienced comments.
    I want to add a HDD to my 120GB SSD equipped PC Desktop.
    Seagate or Western Digital; 1TB to 2TB 7200rpm 64mb cache
    SATA 3 GB or 6GB
    1st pick; Western Digital 1.5 TB Caviar Black SATA 6 Gb/s 7200 RPM 64 MB
    I heard WD makes customer pay shipping.
    2nd pick; Seagate equivalent
    My new build has an SSD OS drive and two 2TB WD Caviar Blacks with 64MB cache. Model number is wd2001fass.
    I don't think it would be very easy to beat these disks. While I haven't run them for long I am very impressed so far.
      ...but the disks I have are 3gbps not 6. The model number for the 6 ends with faex I think. I'm not sure that there is much actual difference in performance once installed.
        HDD manufacturers
        PC Specs; socket 1066 cpu i7-950 ( I don't think 6Gbps is available using i7-950)
        I can not find a negative difference between;
        Are both HDD equal in performance and life?
        Both 2TB 7200 64 cache 6Gbps
        Western Digital BLACK;
        Seagate BARRACUDA;
        Seagate $130.00 & WD $200 +
          WD Black may have a better warranty.
            W.D. Black has a limited 5 year warranty.
            SEAGATE Barracuda is listed @ e-commerce sites as 1 year.
            I will know Monday 19th.
              It might be true that I may be limited to 3 Gbps with my socket 1066 CPU i7-950.
                Damned forgot that my socket is 1366 not 1066.
