TIVO File Conversions
    Will you be adding the option to convert TIVO file formats to DVDFAB in the future or can be done now?
    Do you mean convert a DVD or BD to a file that a Tivo will play or convert files made by a Tivo to something else? There was a Tivo profile in DVD Ripper at one time, not sure if it is still there.
      No Tivo has a utility that allows you to transfer programs to your pc so that you can copy to dvd if they are not covered by Copy protection laws about 75% of the shows you can copy to dvd. I was asking if DVD Fab will have an option that will take the TIVO file format and copy to a dvd. The only program that you can use is Roxio Creator 2011 or 2012 but why would I need to buy another program when I have the best software available to me DVDFab if it can do it.
      Thanks
        There's a program called DirectShowDump that will convert .Tivo files into .mpg files (Assuming you know the MAK), after which you can do whatever you want with them.
          Thanks
          Have you tried the DVD Creator module? It might read them. If not, make a thread about it in the Feature Request forum.
            Getting TiVo transferable files out of DVDFAB
            DVDFab 9 using Ripper function will take a DVD and produce a VOB file for TiVo playback. However If the file turns out bigger that 5GB it will not transfer from TiVo Desktop software into your TiVo player. I have not been able to limit the file output size. This is why DVDFab needs to add a new Device setting for TiVo. If anyone has a fix worked out for this problem please post it.
              You can run the DVD through the DVD Copy module and compress it to DVD-5 size, then process it with Ripper to make the single VOB. Hopefully a VOB/mpg encode-type profile can be added to Ripper in a future version.
