Hello , I ordered 5 TDK BD-R DL from a seller from ebay , the discs seems to be a japanese version of the discs because they have Jap characters. I tried burning an 3D movie image on ImgBurn , as well with nero with no luck.
My burner is a Sony Optiarc BD-5300S , I have the latest firmware 1.06 .
here's the link of my burner with supported media :
ImgBurn Drive Capabilities doesn't have BD-R XL and BD-RE XL checked
My question is , Japanese media works on USA Burners , or i need to change region code or something on ImgBurn ?? Here's a log of ImgBurn but it was a successfully burned image on BD-R Single layer , Regards
I 18:36:45 ImgBurn Version 2.5.7.0 started!
I 18:36:45 Microsoft Windows 7 Ultimate x64 Edition (6.1, Build 7600)
I 18:36:45 Total Physical Memory: 8,359,072 KB - Available: 6,772,036 KB
I 18:36:45 Initialising SPTI...
I 18:36:45 Searching for SCSI / ATAPI devices...
I 18:36:46 -> Drive 1 - Info: Optiarc BD RW BD-5300S 1.04 (E
(ATA)
I 18:36:46 -> Drive 2 - Info: BandRich CDROM 0001 (D
(USB)
I 18:36:46 Found 1 CD-ROM and 1 BD-RE!
I 18:36:46 Operation Started!
I 18:36:46 Source File: C:\Users\isma\Documents\DVDFab\Temp\Clone\IMAX_UND ER_THE_SEA_3D.iso
I 18:36:46 Source File Sectors: 7,498,720 (MODE1/2048)
I 18:36:46 Source File Size: 15,357,378,560 bytes
I 18:36:46 Source File Volume Identifier: IMAX_UNDER_THE_SEA_3D
I 18:36:46 Source File Volume Set Identifier: 3CB4A8C4RDUS0004
I 18:36:46 Source File Implementation Identifier: Ulead Systems USA Inc.
I 18:36:46 Source File File System(s): UDF (2.50)
I 18:36:46 Destination Device: [1:1:0] Optiarc BD RW BD-5300S 1.04 (E
(ATA)
I 18:36:46 Destination Media Type: BD-R (Disc ID: PHILIP-R04-000)
I 18:36:46 Destination Media Supported Write Speeds: 4x
I 18:36:46 Destination Media Sectors: 12,219,392
I 18:36:46 Write Mode: BD
I 18:36:46 Write Type: DAO
I 18:36:46 Write Speed: MAX
I 18:36:46 Hardware Defect Management Active: No
I 18:36:46 BD-R Verify Not Required: Yes
I 18:36:46 Link Size: Auto
I 18:36:46 Lock Volume: Yes
I 18:36:46 Test Mode: No
I 18:36:46 OPC: No
I 18:36:46 BURN-Proof: Enabled
I 18:36:48 Write Speed Successfully Set! - Effective: 17,980 KB/s (4x)
I 18:37:16 Filling Buffer... (80 MB)
I 18:37:17 Writing LeadIn...
I 18:37:18 Writing Session 1 of 1... (1 Track, LBA: 0 - 7498719)
I 18:37:18 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 7498719)
I 18:51:33 Synchronising Cache...
I 18:51:36 Closing Track...
I 18:51:37 Finalising Disc...
I 18:51:52 Exporting Graph Data...
I 18:51:52 Graph Data File: C:\Users\isma\AppData\Roaming\ImgBurn\Graph Data Files\Optiarc_BD_RW_BD-5300S_1.04_TUESDAY-MAY-29-2012_6-36_PM_PHILIP-R04-000_MAX.ibg
I 18:51:52 Export Successfully Completed!
I 18:51:52 Operation Successfully Completed! - Duration: 00:15:02
I 18:51:52 Average Write Rate: 17,561 KB/s (3.9x) - Maximum Write Rate: 19,252 KB/s (4.3x)
I 18:51:52 Close Request Acknowledged
I 18:51:52 Closing Down...
I 18:51:52 Shutting down SPTI...
I 18:51:52 ImgBurn closed!
I 18:36:46 OPC: No
