DVD Ripper to ipad captions issue
    Every time i use DVD ripper to iPad conversion the captions automatically come on. I have tried removing them by unselecting the english captions box but they always come on. I thought maybe when the file is on the ipad2 i could just select an option to not display captions but they are always on. Anyone else have this problem or know how i can fix it?
    Please post the DVDFab internal log from one of these conversions where the subtitles stayed on.
      Sorry I am a rookie, how do i get the Internal log from my conversion?
        Hi r1ch79
        The default location is:
        Please use attachment button and attach your most recent, Internal logand post right here.
        CBR929
          Hey ok finally was able to do this on a recent Ipad conversion I did. I looked at the Log but WOW does that keep a history, lol. I just made one today & here is the log. Thanks for the instructions on how to get it also!
          DVDFab 8.0.9.8 (2012/06/26 07:05:19)
          0m 03.65s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 0 filemover 0
          0m 03.75s: Qt Translator file load success
          0m 11.81s: detected dvd
          0m 11.85s: drive D
          0m 11.85s: dvd type 1
          0m 11.85s: volume label HAPPY_FEET_2
          0m 12.21s: got copyright 1 f6
          0m 12.62s: got udf/iso
          0m 13.79s: got discinfo
          0m 13.79s: pathplayer enabled
          0m 25.85s: got dvdinfo
          0m 25.85s: opened dvd
          35m 17.53s:
          35m 17.53s: create config(0)
          35m 17.53s: convert profile(iPad.h264.1080p)
          35m 19.28s: dvd title(1) angle(0) chapter(1->11)
          35m 19.28s: stream(480,2,1) stream(128,86019,1) stream(32,94208,4)
          35m 19.29s: not set correct fourcc for video(28)
          35m 19.29s: info: set output video frame_rate(24000/1001)
          35m 19.32s: subpicture preset(1), mode(0)
          35m 20.62s: h264_encode: encode param profile(1) level(41) bitrate(7457)
          35m 26.70s: subpicture(32) mode(0)
          35m 26.70s: connect to sub render filter
          35m 33.26s: display only forced subs now 0
          152m 20.60s:
          ------ finish mobile work ------
            Your log indicates that you have a subpicture (subtitles) selected.
            152m 20.60s:
            Here is my log of the same movie with no subpicture selected and no mention of subpicture.
            0m 30.79s: info: create config(0)
            0m 30.79s: info: convert profile(iPad.h264.1080p)
            0m 30.79s: info: dvd playlist(1),angle(0),chapter(1->3),3D(0)
            0m 30.79s: info: streams((480.2)(128.2))
            0m 30.82s: info: not set correct fourcc for video(28)
            0m 30.82s: info: set output video frame_rate(24000/1001)
            0m 31.91s: info: h264_encode: encode param profile(1) level(41) bitrate(12000)
