Hi All,
I've been using DVDFab HD Decryptor for some time. I went to back up a movie this morning and got the "you need to buy or renew DVDFab DVD to DVD ..." error. I've been going through the forums and have seen several others with the same problem. I have yet to find a solution, in the forums, with the possible exception of purchasing DVD Fab.
In the event of a future, possible solution, here's the detailed info of what's going on:
1. I insert the DVD and start DVD Fab.
2. I get the popup titled "Welcome to DVDFab" with the various options listed and whether or not they're expired.
3. I select the bottom option "HD Decryptor" (its listed as enabled and never expire).
4. On the same screen, I click on "OK".
5. It initially reads the DVD, then giving the popup asking to specify the DVD's region code. I select the proper one and click on "OK".
6. It tries to open the DVD source for a few seconds, then displays the following pop-up error message: "To open the DVD disc, you need to buy or renew DVDFab "DVD to DVD", or you can wait for new version of DVDFab HD Decryptor." The only option given is to click on "OK" at which point it stops trying to open the source DVD.
Running it from the blue question mark, at the top, from "About" gives exactly the same results.
I'm using version 6.1.2.5 and Vista Home Premium x64.
So, is there a way to get HD Decryptor to rip the DVD to the hard drive ?
Thanks
Thanks
