LiteOn iHES112
    LiteOn iHES112
    I bought a LiteOn iHES112 Blu-ray player. This is an internal SATA connected drive. Everything seems to be installed alright, and when I open Windows Media Player I can play the DVD in the drive without any issues, but DVDFab is acting really weird.
    It will not open the DVD for about 10 minutes. It is just sitting there doing nothing, looking like it's hanging. Then it will show the "opening DVD" window, the one with the progress bar that keeps going, and it will keep going through the progress bar forever, never completing. I tired several DVDs and a blu ray, all with the same results.
    My previous DVD player worked fine, no issues whatsoever, and I did not change any settings or software (well, I re-installed DVD Fab to see if that was the issue). There is no other ripping software running on my machine.
    Is there anything I can look at or post up here to help you address this issue, or to help me fix this issue?
    Also post your internal.log if your device still has problem.
      DVDFab 8.2.0.8 (2012/09/10 18:34:32)
      0m 01.88s: GPUAccelerate: 0
      0m 01.88s: CUDA cap: 0
      0m 01.88s: Support coreavc decode: 0
      0m 01.88s: Graphics info: NVIDIA GeForce 6800 : :
      0m 01.89s: Qt Translator file load success
      0m 02.10s: Load config successful.
      0m 02.34s: Init profile data driver sucessful.
      0m 09.09s: Init GPU settings sucessful.
      0m 09.09s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
      0m 09.10s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
      0m 09.90s: Config ExBar successful.
      0m 09.90s: dvd2dvd have 8 elements.
      0m 10.58s: dvd2mobile have 31 elements.
      0m 12.76s: blu-ray2blu-ray have 4 elements.
      0m 12.85s: blu-ray2mobile have 20 elements.
      0m 14.84s: blu-ray23d have 7 elements.
      0m 15.43s: blu-ray2dvd have 1 elements.
      0m 15.51s: file2mobile have 30 elements.
      0m 18.18s: file2dvd have 1 elements.
      0m 18.26s: file2bluray have 1 elements.
      0m 19.30s: Config work ui controls successful.
      0m 29.33s: Init burn engine successful.
      0m 29.40s: StartNotify successful.
      0m 29.44s: opening drive F
      1m 19.13s: GPUAccelerate: 0
      1m 19.13s: CUDA cap: 0
      1m 19.13s: Support coreavc decode: 0
      1m 19.13s: Graphics info: NVIDIA GeForce 6800 : :
      9m 12.87s: got media type 15
      9m 13.26s: got max lba 24438783
      9m 14.16s: type Blu-ray BDMV
      9m 14.16s: volume label FIREFLYUS_D1
      9m 14.65s: opening drive F
      9m 15.22s: got max lba 24438783
      9m 16.13s: aacs 1 bd+ 1
      32m 09.03s: Java protection is removed by StealthyClone anti-protection.
      32m 09.72s: got discinfo
      33m 22.88s: got bdmv
      33m 33.89s: Vendor: ATAPI
      33m 33.89s: Product: iHES112 3
      33m 33.89s: Revision: ML04
      33m 33.89s: Vendor specific: 2012/05/24 09:48
      33m 33.89s: AACS version: 1
      33m 33.89s: Number of concurrent AGIDs: 3
      33m 33.89s: Supports bus encryption: YES
      33m 33.89s: Supports binding nonce generation: NO
      33m 33.89s: Supports Hybrid discs: NO
      33m 33.89s: got agid 0
      33m 34.74s: sent host cert chal
      33m 34.75s: got drive cert chal
      33m 34.75s: BEC 1
      33m 34.75s: DRIVE_VENDOR 0x0080
      33m 36.05s: got drive key
      33m 41.76s: got host key signature
      33m 41.76s: verified drive signature
      33m 41.76s: verified host signature
      42m 20.27s: sent host signature and key point
      42m 20.29s: got bus key
      42m 24.50s: got agid 0
      42m 25.39s: sent host cert chal
      42m 25.40s: got drive cert chal
      42m 25.41s: BEC 1
      42m 25.41s: DRIVE_VENDOR 0x0080
      42m 26.79s: got drive key
      42m 26.79s: got host key signature
      42m 26.80s: verified drive signature
      42m 26.80s: verified host signature
      42m 28.30s: sent host signature and key point
      42m 28.31s: got bus key
      42m 28.36s: got volume id
      42m 28.39s: got volume id mac
      42m 28.39s: volume id is correct
      42m 28.40s: got vid
      42m 29.03s: blu-ray 4A4D707C04BE59151D1FA930DA7406263E559E7B
      43m 00.29s: cert BEE=0x00 same
      43m 01.24s: D 96EE3EF6
      47m 24.47s: got vuk
      47m 24.47s: got fut
      47m 34.89s: got agid 0
      47m 35.74s: sent host cert chal
      47m 35.75s: got drive cert chal
      47m 35.75s: BEC 1
      47m 35.75s: DRIVE_VENDOR 0x0080
      47m 37.09s: got drive key
      47m 37.09s: got host key signature
      47m 37.09s: verified drive signature
      47m 37.09s: verified host signature
      47m 38.58s: sent host signature and key point
      47m 38.58s: got bus key
      47m 38.61s: got data key
      47m 38.70s: got unit key 7
      54m 07.14s: got extended bdinfo
      54m 07.14s: opened blu-ray
        Sorry for taking so long to post that up. It's been kind of busy.
        Just take a look at how long everything takes.
        This is the part that seems like nothing is happening:
          DVDFab is having trouble communicating with the new drive. Please install DVDFab Inspector (free) and look on the filters tab and see what else is using low level access to the drive.
            The "Filter Driver" tab is completely empty
              Then I have no guess, other than to check the BIOS and see if it has any settings for the optical drive or I/O that may effect this. When DVDFab queries the drive, the response is very slow, as shown in the log at 0:29.44 and the fact that it took an hour just to open the disc. Sometimes there are settings for the SATA controller or AHCI that will help in problems like this. Is it equally slow with a DVD in the drive?
              ////EDIT///////// In looking around on other forums, there have been reports of problems with this drive. Others report CD or DVD work OK, Blu-ray not so much. Not sure if that is what you are seeing.
                I am still not in business with DVD Fab. DVDs have the same issue and I can't rip them either. Is there anything I can do to get this working?
                I love DVDFab, and may just remove this drive and change back to DVD only so I have Fab back again.
                  Hi RobertDD
                  Do you have the drivers installed for your GPU?
                  Another thing to try Please Open Fab click the Click the Green at top right corner of the DVD Fab screen, and open Common Settings > General >DVD/ Blu-ray > Read>I/O Mode try changing the settings to either Auto, ASPI, or SPTI and see if Fab can now recognize the disc.
                  Hope this helps
                  CBR929
