I'm a register owner of DvdFab and a while back I also bought Videofab converter. I notice when I open DvdFab, I have options to run File to Mobile and File Mover which are similar to Videofab. I would like to know if there is a way for Videofab owners to register into DVDfab so all programs can run under one window and not have to open two seperate programs. I also notice there has been only one update for Videofab and I was wondering if File to Mobile and File Mover have received several updates compared to Videofab.
Request for VideoFab owners to merge with their register DvdFab program
--------------------------------------------------------------------------------Originally posted by judo54 View PostI'm a register owner of DvdFab and a while back I also bought Videofab converter. I notice when I open DvdFab, I have options to run File to Mobile and File Mover which are similar to Videofab. I would like to know if there is a way for Videofab owners to register into DVDfab so all programs can run under one window and not have to open two seperate programs. I also notice there has been only one update for Videofab and I was wondering if File to Mobile and File Mover have received several updates compared to Videofab.
VideoFab Converter
•Existing licenses for the product are automatically incorporated into the v6 registration keys.
•Please install the latest v6 update and obtain a new registration key (free) using the link at the bottom of this page.
Formerly DVDKingdom
VideoFab IS File to Mobile now. Follow the links DVDKingdom thoughtfully provided and all should be fine.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
When you requested the new key, did you select "all in one email" from the drop down selector? Same email address from when you registered VideoFab to now? If so, should have worked. Sorry you are having trouble, we will get this figured out.
//EDIT// Which method did you use to register the new key, cut and paste or double click on key attachment?Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
What about the "all in one" option (I think it is the default now, it was not at one time)?
You might try uninstalling DVDFab (using the Fab uninstaller in Start->Programs->DVDFab 6), then reinstall and reregister using your new key. Put the key in a safe place during the uninstall. I always email mine to myself.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
