I don't know what is actually happening with my IMGBurn software. This is the first time I started having problems with it. I tried to burn a copy of a movie (any) and it just won't do it. Here's a picture of what it does for 10 minutes or so. What do I need to do to fix this problem? Thanks.
IMGBurn
It is not communicating well with your drive. Note that the device buffer is empty. As Jon noted, the log would help determine what is happening.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Here's the only log I found. Hope this helps!
I 13:51:40 ImgBurn Version 2.5.7.0 started!
I 13:51:40 Microsoft Windows 7 Home Premium x64 Edition (6.1, Build 7601 : Service Pack 1)
I 13:51:40 Total Physical Memory: 8,370,724 KB - Available: 5,048,124 KB
I 13:51:40 Initialising SPTI...
I 13:51:40 Searching for SCSI / ATAPI devices...
I 13:51:40 -> Drive 1 - Info: hp DVD A DH16ABLH 3HD9 (E
(ATAPI)
I 13:51:40 Found 1 DVD±RW/RAM!
I 13:51:40 Operation Started!
I 13:51:40 Building Image Tree...
I 13:51:41 Checking Directory Depth...
I 13:51:41 Calculating Totals...
I 13:51:41 Preparing Image...
I 13:51:41 Checking Path Length...
I 13:51:41 Contents: 9 Files, 2 Folders
I 13:51:41 Content Type: DVD Video
I 13:51:41 Data Type: MODE1/2048
I 13:51:41 File System(s): ISO9660, UDF (1.02)
I 13:51:41 Volume Label: PREMIUM_RUSH
I 13:51:41 IFO/BUP 32K Padding: Enabled
I 13:51:41 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
I 13:51:41 TV System: NTSC
I 13:51:41 Size: 4,487,217,152 bytes
I 13:51:41 Sectors: 2,191,024
I 13:51:41 Image Size: 4,487,839,744 bytes
I 13:51:41 Image Sectors: 2,191,328
I 13:51:41 Operation Successfully Completed! - Duration: 00:00:00
I 13:51:41 Operation Started!
I 13:51:41 Source File: -==/\/[BUILD IMAGE]\/\==-
I 13:51:41 Source File Sectors: 2,191,328 (MODE1/2048)
I 13:51:41 Source File Size: 4,487,839,744 bytes
I 13:51:41 Source File Volume Identifier: PREMIUM_RUSH
I 13:51:41 Source File Volume Set Identifier: 41976E7400216FD7
I 13:51:41 Source File Application Identifier: IMGBURN V2.5.7.0 - THE ULTIMATE IMAGE BURNER!
I 13:51:41 Source File Implementation Identifier: ImgBurn
I 13:51:41 Source File File System(s): ISO9660, UDF (1.02)
I 13:51:41 Destination Device: [0:1:0] hp DVD A DH16ABLH 3HD9 (E
(ATAPI)
I 13:51:41 Destination Media Type: DVD+R (Disc ID: MCC-004-00)
I 13:51:41 Destination Media Supported Write Speeds: 6x, 8x, 12x, 16x
I 13:51:41 Destination Media Sectors: 2,295,104
I 13:51:41 Write Mode: DVD
I 13:51:41 Write Type: DAO
I 13:51:41 Write Speed: 16x
I 13:51:41 DVD+R Reserve Track: No
I 13:51:41 Link Size: Auto
I 13:51:41 Lock Volume: Yes
I 13:51:41 Test Mode: No
I 13:51:41 OPC: No
I 13:51:41 BURN-Proof: Enabled
I 13:51:41 Write Speed Successfully Set! - Effective: 22,160 KB/s (16x)
I 13:51:41 Filling Buffer... (80 MB)
I 13:51:43 Writing LeadIn...
I 13:52:17 Writing Session 1 of 1... (1 Track, LBA: 0 - 2191327)
I 13:52:17 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2191327)
I 13:57:10 Synchronising Cache...
I 13:57:12 Closing Track...
I 13:57:13 Finalising Disc...
I 13:57:29 Exporting Graph Data...
I 13:57:29 Graph Data File: C:\Users\Jessica\AppData\Roaming\ImgBurn\Graph Data Files\hp_DVD_A_DH16ABLH_3HD9_SUNDAY-DECEMBER-23-2012_1-51_PM_MCC-004-00_16x.ibg
I 13:57:29 Export Successfully Completed!
I 13:57:29 Operation Successfully Completed! - Duration: 00:05:41
I 13:57:29 Average Write Rate: 14,957 KB/s (10.8x) - Maximum Write Rate: 21,931 KB/s (15.8x)
I 13:57:29 Close Request Acknowledged
I 13:57:29 Closing Down...
I 13:57:29 Shutting down SPTI...
I 13:57:29 ImgBurn closed!
Hi dragongirl2010
I agree your burning to fast even though your using Verbatim discs, try slowing it down to 8X.
Have you also changed any of the settings in ImgBurn?
Reason for asking is my buffer size it set to 40mb and yours is showing 80mb
If so try setting your buffer to 40mb
Open ImgBurn click tools>settings>build>page 2>top right is a slider , set it to 40mb and click OK.
Hope this helps
CBR929
Edit: It's also strange that your pic shows no room on the disc sectors-0, size-0.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
The new default buffer size is 80MB, if you have above a certain amount of RAM.Originally posted by CBR929 View PostReason for asking is my buffer size it set to 40mb and yours is showing 80mb
Hope this helps
2.5.7.0
Changed: Default size of I/O Buffer. (Less than 1GB RAM = 20MB, Less than 2GB RAM = 40MB, Everything else = 80MB)
imgburn, imgburner, img burn, img burner, imageburn, imageburner, image burn, image burner, image write, image writer, iso burner, iso writer, cd burner, dvd burner, bin, cue, gcm, gi, img, iso, lst, nrg, mds, pdi, burn, burner, write, writer, image, drive, cuesheet, lightning uk, dvd decrypter, backup, cd, cdr, cdrw, dvd, dvdr, dvd-r, dvd-rw, dvd-r dl, dvd+r, dvd+rw, dvd+r dl, dvdram, hd dvd-r, hd dvd-rw, hd dvd-ram, bd-r, bd-re, dual layer, double layer, bluray, blu ray, blu-ray, hddvd, hd dvd, hd-dvd, burn audio, write audio, burn bin, write bin, burn cue, write cue, burn dvd, write dvd, burn iso, write iso, burn img, write img, write image, burn video_ts, write video_ts, burn bdmv, write bdmv, burn dvd video, write dvd video, burn bluray, write bluray, burn blu-ray, write blu-ray, layerbreak, layer break, VIDEO_TS, bup ifo vob
Thanks Gummi
During leadin writing that buffer is always empty. It's first when it starts to write the buffer is filled.Originally posted by signals View PostIt is not communicating well with your drive. Note that the device buffer is empty. As Jon noted, the log would help determine what is happening.
Looks more as the burner has a hard time writing to those discs, try to slow down the burn as suggested in this thread.
Did you try to slow down the write speed to 8x as suggested by CBR929?Originally posted by dragongirl2010 View PostI changed the buffer size to both 40mb and 20mb and still no luck. I forgot to ask about the size and sector sections, back then both were not set at zero. When I changed the buffer size, the sector and size were still the same, 0.
