I have a Dell system with (currently) Windows 7 64-bit and Fab 9.0.4.0. My drive is currently a LiteOn iHAS 124-04 SATA drive, which is Windows 7 certified. I was previously trying to use a SONY Optiarc AD-7200S ATA drive, which is also a SATA drive but is not Windows 7 certified. I also was previously running the 64-bit version of Windows Vista.
My problem is that with BOTH of these SATA drives and BOTH OSes, Fab cannot read my DVDs. I previously also was trying to use version 8.0.8.5, and NEITHER would read either of my SATA drives. Here are a couple of example log files:
8.0.8.5 Burn log:
2013-05-16 11:59:01 ---- ******************** Log session stop 16-May 11:59:01.120 PID 640********************
2013-05-16 11:54:38 Info Current Drive selected : 4:0:0 - ATAPI iHAS124 W HL04 [E] (Ide)
2013-05-16 11:54:38 Info Using Advanced SPTI interface
2013-05-16 11:54:38 Info System default language : English (United States)
2013-05-16 11:54:38 Info User default language : English (United States)
2013-05-16 11:54:38 Info DLL Version : 4.0.15.480
2013-05-16 11:54:38 Info DLL : C:\Program Files (x86)\DVDFab 8\vso_hwe.dll
2013-05-16 11:54:38 Info Version : 8, 0, 8, 5
2013-05-16 11:54:38 Info ExeName : C:\Program Files (x86)\DVDFab 8\DVDFab.exe
2013-05-16 11:54:38 Info OS : Microsoft Windows 7 Professional (Build 7601: Service Pack 1)
2013-05-16 11:54:38 ---- ******************** Log session start 16-May 11:54:38.976 PID 640********************
8.0.8.5 Internal log:
DVDFab 8.0.8.5 (2013/05/16 14:24:46)
0m 00.88s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
1m 49.29s: detected dvd
1m 49.35s: drive E
1m 49.35s: dvd type 1
1m 49.35s: volume label GS
15m 10.51s: got copyright 0 0
15m 10.51s: opened dvd
9.0.4.0 Internal log:
DVDFab 9.0.4.0 (2013/05/17 11:02:02)
0m 00.18s: Start preload dll...
0m 00.24s: Load dll successful.
0m 00.28s: Start load fabplay dll...
0m 00.37s: Load fabplay dll successful.
0m 00.37s: Windows os type is: 13.
0m 00.37s: Transfer settings successful.
0m 00.63s: GPUAccelerate: 12345
0m 00.63s: CUDA cap: 0
0m 00.63s: Support coreavc decode: 0
0m 00.63s: Graphics info: : :
0m 00.63s: import key file E:\ 1
0m 00.65s: Load config successful.
0m 00.65s: Qt Translator file load success
0m 00.71s: Start get sys number.
0m 00.73s: Serial number is: 00-24-2b-7d-a6-7b
0m 00.73s: Reg URL link is:
0m 00.73s: Version is: 9040
0m 00.73s: Product is: 2
0m 00.73s: Connect type is: 0
0m 01.46s: Times of connecting error is: 0
0m 01.46s: Parse string is: 2:8260762964
0m 01.46s: Parse string is: 11:8260762964
0m 01.46s: Parse string is: OV:9040
0m 01.46s: Parse string is: BV:9039
0m 01.46s: Parse string is: S:791fa45b59c3cf2d9c3e8ba1b371b7d6
0m 01.74s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1
0m 01.74s: End check info.
0m 01.95s: Init profile data driver sucessful.
0m 01.95s: Init GPU settings sucessful.
0m 02.69s: Profile Manager :: End Load Profile
0m 08.12s: Begin init preview play engine.
0m 08.12s: Init DirectShow engine successful.
0m 08.36s: Init burn engine successful.
0m 08.70s: opening drive E
I have played with different I/O modes, and gotten no difference. I installed ImgBurn, which is able to burn to my new drive. I'm also able to play DVDs with Media Player.
One reason that I suspect the magic combo of SATA drives and 64 bit OSes is that, after considerable reading of the forums, I have not read anything about the combination of SATA and 64 bit working successfully. Every time I try to read a DVD, Fab hangs and will not release back to the OS, requiring a reboot.
I think I've tried everything, but welcome any suggestions you guys might have.
8.0.8.5 Burn log:
1m 49.35s: drive E
