I played the original disc - no subtitles and without any adjustment put in the backup and the subtitles were on. Something is turning them on and it's not a leftover player setting, popped the original back in and no subtitles.
Subtitles
Originally posted by 90312 View PostI played the original disc - no subtitles and without any adjustment put in the backup and the subtitles were on. Something is turning them on and it's not a leftover player setting, popped the original back in and no subtitles.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Those are the ones I sent you signals, I thought those were the ones you wanted. Want them off the original?How to post the internal log
Nah, if the ones you sent were from the burned disc itself, that is perfect.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Update: this is apparently not a DVDFab issue according to the experts, based on the evidence so far. Using Main Movie, the default arrow produces a unique signature in the VTS_01_0.IFO file when it is set (a pre-command) that is not present in the IFO file that 90312 sent me or the ones that I made to try to duplicate the problem. Try a completely different player that has never played the disc or folder (e.g. VLC).Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
