2m 38.23s: read error: 3 868952 3909418 1921520 0 8 868952
3m 04.03s: read error: 3 868952 3909418 1921520 0 8 868952
I pulled these read errors from your multi logs i don't know what disk being you used 2 different ones.If you delete the old logs and redo it and post new logs with the latest version of Fab we can tell more.This is the only way I can help you.
You can do one with and one without pathfinder.Seems you were able to put Riddick on the hard drive as you were trying other things from the drive.Somehow you made a avi did it play correct through the whole disk?
On the second disk that looked clean look for scratches bend it while holding it while a light source is on it.(Don't bend the disk)
Because you seem to have put the disk on the drive and made a AVI I don't think it's copy protection.
