9.1.2.5
Been using dvdfab for a while. Had an amd triple core phenom was using an older version of dvdfab. Would rip DVD's slow. at like 15fps. Upgraded to a 2nd gen Core i5 laptop. It automatically enabled intel gpu encoding and would rip at 150ish fps. Then I upgraded to 9.1.2.5 It no longer told me it was gpu enabled and it would rip at around 50-80fps.
Sold and upgraded laptop's again. 3rd gen core i5. Installed 9.1.2.5 and it was intel enabled from the beginning but wouldn't even start the whole program would freeze once I hit start. I was playing around and I disabled all gpu codecs for decoding and encoding. Now it works fine. Rips at the usual 50-80fps.
Is this an issue with 9.1.2.5? Or do I need to change some settings?
Hopefully this all makes sense I feel like I rambled.
