defaulted to clone
    defaulted to clone
    help please
    When I go to copy the program defaults to clone and I choose main movie.
    I am running w8, dvdfab 9.1.4.0
    I went through settings to look for a default change button no luck there so now I'm lost
    can anyone help?
    thank qman
    Select the Copy mode you want after you insert the disc. It should open with the same copy mode you used last.
      default to clone
      HI
      It changes when i put in the disc i do not use clone, Do you think t might be a bad disc? I am starting to think that because I ran other discs and they worked. Just a thought, I baffled.
        I do not understand it, and I can't duplicate the problem. Possibly something related to that specific disc or the application/driver environment on your PC.
          Default to clone
          My DVD Copy is also defaulting to clone, rather than full disc or main movie. I've never cloned, only full disc or main movie. This is since the most recent update and there is nowhere to change the default. This is the third time with different discs so it's not any specific disc. It's the update to 9.1.9.9. It is a major, major pain to try to reset it to full disc, many extra steps and lots of lost time. Can anyone tell me how to fix this so it will default to full disc? Even when exiting and re-entering the program it doesn't go to the last setting I used; it always goes to clone.
            What is your OS? It defaults to last used for Blu-ray for me, should for DVD also. Two clicks should bring it to Full Disc no matter what it opens with.
              I suppose that the DVD disc does not read correctly for some reason.
              DVDFab will change to Clone default when opening a data disc.
              Did you use a DVD movie disc?
              Would you please post dvdfab internal log file?
              Or try these steps:
              - Uninstall the old version and install the latest version 9199 first.
              - Insert DVD disc to your DVD-ROM and wait Windows Explorer read done.
              - Start DVDFab and see the result again.
                Here's the last log from the disc that worked when I switched it to copy yesterday.
                DVDFab 9.1.9.9 (2015/05/12 15:24:24)
                0m 00.03s: Init Public log : enabled.
                0m 00.04s: Init Private log : finish.
                0m 00.05s: App info: 2015-4-28
                0m 00.05s: App info: 9.1.9.9 9199 Official
                0m 00.07s: Init CrashReportSettings : enabled.
                0m 00.07s: Init DVDInfo_Log : enabled.
                0m 00.08s: Init Qt_Log : disabled.
                0m 00.21s: Profile Manager :: Begin Load Profile
                0m 00.21s: Qt Translator file load success
                0m 00.22s: App info: client type 10.
                0m 00.25s: MobilePlay load: preload successful.
                0m 00.41s: MobilePlay load: Load successful.
                0m 00.42s: Init process: Transfer settings successful.
                0m 00.43s: info: check logpath= C:/Users/Velvet/Documents/DVDFab9/Log/
                0m 00.44s: info: _check_gpu is running ...
                0m 00.63s: info: check_gpu run successful
                0m 00.63s: info: recommand= 851968, Shrink support= 1, enable= 1, cuda_cap= 0 , cpu_count= 4
                0m 00.64s: GPU check: GPUAccelerate-851973
                0m 00.64s: GPU check: GPUAccelerate setting-851968, 851968
                0m 00.64s: GPU check: CUDA cap-0
                0m 00.65s: GPU check: Support coreavc decode-0
                0m 00.65s: GPU check: Lighting shrink status-1, 1
                0m 00.66s: GPU check: Graphics info 1: Intel(R) HD Graphics 4000 : 10.18.10.3412 : 4,3
                0m 00.67s: Init process: Load config failed.
                0m 00.68s: Init process: Windows os type is 64bit System Windows 8.
                0m 00.69s: Init process: command line in is
                0m 00.77s: Reg check: Parse string: ( 2:8260762964 )( 1:21 )( 50:0 )( OV:9199 )( BV:9197 )( S:a975ca57cfb3c98b97a6e48cfb826b6f )
                0m 00.79s: Reg check: Option check status-Local
                0m 00.79s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):1:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:0 )-( Blu-ray to Blu-ray:1:0 )-( Blu-ray to Mobile:1:0 )-( File to Mobile:0:0 )-( Blu-ray to DVD:1:0 )-( DVD to Blu-ray:1:0 )-( File to DVD:1:0 )-( File to Blu-ray:1:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:0 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-
                0m 00.80s: App info: language type ENU.
                0m 00.80s: App info: Install path C:/Program Files (x86)/DVDFab 9 US/
                0m 00.81s: Export Blu-ray source information report : disabled
                0m 00.82s: Reg check: Start get sys number.
                0m 00.82s: Init process: Init GPU settings successful.
                0m 00.83s: connect plugin info : start.
                0m 00.83s: Reg check: Serial number is: a4-17-31-aa-a0-cc:16-17-31-aa-a0-cb:a4-17-31-aa-a0-cb:e0-db-55-d4-23-9a
                0m 00.85s: Reg check: Connect type is: 0
                0m 01.75s: connect plugin info : 1:1
                0m 01.83s: Reg check: Times of connecting error is: 0
                0m 01.84s: Reg check: Parse string: ( S:929f2ffaef2c7d387fc60f18667f08a9
                0m 01.86s: Reg check: Option check status-NewWork
                0m 02.85s: Profile Manager :: End Load Profile
                0m 03.31s: Init preview: Begin init preview play engine.
                0m 03.33s: Init preview: Begin init preview play engine(Internal).
                0m 03.50s: Init preview: Init internal engine successful.
                0m 04.46s: Burn engine: start init.
                0m 04.47s: Burn engine: set log folder.
                0m 04.47s: DVD: init read settings.
                0m 04.48s: DVD: init write settings.
                0m 04.48s: DVD: DVDInfo_SetDvdrBlocks size = 2201600
                0m 04.49s: DVD: after DVDInfo_SetDvdrBlocks
                0m 07.02s: DVD: after SetBurnEngine, Burn Type = 0
                0m 07.02s: DVD: after init write settings.
                0m 07.02s: DVD: finish init write settings.
                0m 07.03s: BD: init read settings.
                0m 07.03s: BD: init write settings.
                0m 07.04s: bd set region A
                0m 07.05s: Burn engine: config engine type-0 begin.
                0m 07.05s: Burn engine: config engine type-0 end.
                0m 07.06s: Burn engine: writer count 2.
                0m 07.06s: Burn engine: 0- D:\ [HL-DT-ST DVD+-RW GU70N A102 (Scsi)].
                0m 07.07s: Burn engine: 1- F:\ [HL-DT-ST DVD+-RW GX10N A106 (Usb)].
                0m 07.07s: Burn engine: end init.
                0m 08.03s: Init process: Init setting page successful.
                0m 08.04s: QtLog Mode = false
                0m 08.04s: Show UI Step 2
                0m 08.63s: Show UI Step 3
                0m 08.64s: Start show MainUI.
                0m 08.65s: UI manager: switch to Copy mode.
                0m 10.03s: Init process: init main ui successful.
                0m 10.77s: Plugin Info : 1 exits flag = false plugin path = C:/Program Files (x86)/DVDFab 9 US/Plugins\VideoDownload.xml
                0m 10.82s: Init process: show main ui successful.
                0m 10.82s: DriveX msg: Init driveX D with I/O mode: 0
                0m 10.83s: DriveX msg: Init driveX E with I/O mode: 0
                0m 10.84s: DriveX msg: Init driveX F with I/O mode: 0
                0m 10.86s: opening drive E
                0m 10.86s: opened i/o
                0m 10.87s: failed to get configuration: sensekey 05 asc 20 acsq 00
                0m 10.88s: got max lba 342015
                0m 10.94s: got disc type 0
                0m 10.94s: DriveX msg: add media in driveX E.
                0m 10.95s: DriveX msg: send open media msg to thread for driveX E.
                0m 10.96s: opening drive F
                0m 10.97s: opened i/o
                0m 10.97s: got media type 4
                0m 13.89s: got max lba 3111567
                0m 13.91s: got disc type 10
                0m 14.00s: type DVD-VIDEO
                0m 14.01s: volume label NATM_3_SECRET_OF_THE_TOMB
                0m 14.02s: DriveX msg: add media in driveX F.
                0m 14.02s: DriveX msg: send open media msg to thread for driveX F.
                0m 14.03s: opening drive D
                0m 14.04s: opened i/o
                0m 14.06s: Source managerpen source flag:1,1,1,1,1
                0m 14.07s: Source managerpen source flag:1,1,1,1,1
                0m 14.08s: Source managerpen source flag:1,1,1,1,1
                0m 14.08s: Source manager: add source id 0.
                0m 15.10s: Source manager: open successful.
                0m 15.11s: UI manager: switch to Copy mode.
                0m 16.36s: Work manager: create DVD clone work 0 with source 0 and uiinfo 0.
                0m 16.47s: Source managerpen source flag:1,1,1,1,1
                0m 16.47s: Source manager: add source id 1.
                0m 16.50s: Source open statusVD Yes, 2231-10-11
                0m 16.50s: Source open status:BD Yes, 2158-1-1
                0m 16.51s: internal path F:/VIDEO_TS/
                0m 16.55s: got copyright 1 fe
                0m 16.57s: key method 0
                0m 17.13s: got udf/iso
                0m 18.85s: got discinfo
                0m 18.87s: pathplayer enabled
                0m 21.77s: button: vts_4 menu_1 pgc_12 cell_1 start_0 end_9963 sector_5964 count_4
                0m 41.99s: button: vts_4 menu_1 pgc_13 cell_1 start_9964 end_18979 sector_10074 count_4
                0m 42.14s: button: vts_4 menu_1 pgc_14 cell_1 start_18980 end_19094 sector_18980 count_9
                0m 42.27s: button: vts_4 menu_1 pgc_15 cell_1 start_19095 end_19212 sector_19095 count_16
                0m 42.42s: button: vts_4 menu_1 pgc_15 cell_2 start_19213 end_19330 sector_19213 count_16
                0m 42.50s: button: vts_4 menu_1 pgc_15 cell_3 start_19331 end_19448 sector_19331 count_16
                0m 42.67s: button: vts_4 menu_1 pgc_15 cell_4 start_19449 end_19566 sector_19449 count_16
                0m 42.75s: button: vts_4 menu_1 pgc_15 cell_5 start_19567 end_19684 sector_19567 count_16
                0m 42.88s: button: vts_4 menu_1 pgc_15 cell_6 start_19685 end_19802 sector_19685 count_16
                0m 43.04s: button: vts_4 menu_1 pgc_15 cell_7 start_19803 end_19920 sector_19803 count_16
                0m 43.06s: button: vts_4 menu_1 pgc_16 cell_1 start_19921 end_20034 sector_19921 count_6
                0m 48.42s: got dvdinfo
                0m 48.61s: opened dvd
                0m 50.10s: Source manager: open successful.
                0m 51.53s: Work manager: create DVD clone work 1 with source 1 and uiinfo 1.
                0m 51.62s: Source managerpen source flag:1,1,1,1,1
                1m 50.48s: Work manager: create DVD fulldisc work 2 with source 1 and uiinfo 2.
                2m 07.83s: UILog:OnMsgToolbar_Start
                2m 07.85s: UILog:Msg Start : ready start
                2m 07.86s: UILog:Msg Start : start test run work
                2m 07.88s: UILog:right button to null, work falg = -1
                2m 07.96s: UILog:Msg Start : run work
                2m 07.96s: UILog:Run current Work.
                2m 07.97s: UILog:Begin work copy or converter.
                2m 07.97s: UILog:start running at thread.
                2m 07.99s: UILog:return flag at start running at thread ok.
                2m 08.05s: UILog:MsgWork:WorkStatus_Start
                2m 08.14s: DVD Copy
                2m 08.14s: Source: F:/
                2m 08.15s: SourceSize: 6075 MB
                2m 08.15s: OutputSize: 4300 MB
                28m 37.35s: DriveX msg: remove media in driveX F.
                28m 37.38s: UILog:MsgWork:WorkStatus_Start
                28m 37.67s: Source managerpen source flag:1,0,1,1,1
                29m 08.08s: opening drive F
                29m 08.11s: opened i/o
                29m 08.12s: got media type 5
                29m 08.14s: got max lba 0
                29m 08.15s: DriveX msg: media open(false) failed in driveX F.
                29m 10.21s: Burn data size is: 4300
                29m 10.22s: Burn disc space is: 4488
                29m 10.66s: burn folder C:\Users\Velvet\Documents\DVDFab9\Temp\FullDisc\NA TM_3_SECRET_OF_THE_TOMB\ with VSO
                41m 27.26s: DriveX msg: remove media in driveX F.
                41m 28.34s: UILog:MsgWork:current work finish : 3
                41m 28.39s: connect 0 : start.
                41m 28.54s: connect 0 : 1:1
                41m 29.55s: Source managerpen source flag:1,0,1,1,1
                41m 32.01s: UILog:OnMsgToolbar_BurnFinish
                41m 32.02s: UILog:MsgWork:current work finish : 3
                41m 32.02s: UILog:Run Work to end.
                41m 34.11s: Source managerpen source flag:1,1,1,1,1
                41m 43.53s: Exit process: stop running.
                41m 43.56s: Exit process: preview pfn_releaseplayer end
                41m 43.58s: Exit process: preview pfn_deinit end
                41m 43.63s: Exit process: preview FreeLibrary end
                41m 43.64s: Exit process: finish MainUI.
                41m 43.71s: Exit process: finish FreePref.
                41m 43.73s: Exit process: finish AVEditWrap Release.
                0m 00.04s:
                  I'm using windows 8.1.
                  Also, when I start the program without a disc in it keeps it at full disc. When I put a disc in it changes to clone so I have to hit cancel. But then if I switch it to full disc it keeps the clone task in the queue so I have to go into that and delete it and go back to restart it as a full copy, which most of the time doesn't work on the first try. It's the strangest thing.
                  And the last four discs I've tried now have been movie discs, from all different time periods (old and newer).
                  Thanks for any help you can offer!
                    Here's the log from the one just prior to the last one I posted. I believe it's when it switched itself from full disc to clone and I canceled it.
                    DVDFab 9.1.9.9 (2015/05/12 15:22:57)
                    0m 00.07s: Init Public log : enabled.
                    0m 00.08s: Init Private log : finish.
                    0m 00.09s: App info: 2015-4-28
                    0m 00.09s: App info: 9.1.9.9 9199 Official
                    0m 00.10s: Init CrashReportSettings : enabled.
                    0m 00.11s: Init DVDInfo_Log : enabled.
                    0m 00.12s: Init Qt_Log : disabled.
                    0m 00.26s: Profile Manager :: Begin Load Profile
                    0m 00.26s: Qt Translator file load success
                    0m 00.29s: App info: client type 10.
                    0m 00.34s: MobilePlay load: preload successful.
                    0m 00.45s: MobilePlay load: Load successful.
                    0m 00.53s: Init process: Transfer settings successful.
                    0m 00.54s: info: check logpath= C:/Users/Velvet/Documents/DVDFab9/Log/
                    0m 00.55s: info: _check_gpu is running ...
                    0m 01.03s: info: check_gpu run successful
                    0m 01.04s: info: recommand= 851968, Shrink support= 1, enable= 1, cuda_cap= 0 , cpu_count= 4
                    0m 01.06s: GPU check: GPUAccelerate-851973
                    0m 01.07s: GPU check: GPUAccelerate setting-851968, 851968
                    0m 01.08s: GPU check: CUDA cap-0
                    0m 01.09s: GPU check: Support coreavc decode-0
                    0m 01.09s: GPU check: Lighting shrink status-1, 1
                    0m 01.10s: GPU check: Graphics info 1: Intel(R) HD Graphics 4000 : 10.18.10.3412 : 4,3
                    0m 01.14s: Init process: Load config failed.
                    0m 01.15s: Init process: Windows os type is 64bit System Windows 8.
                    0m 01.16s: Init process: command line in is
                    0m 01.31s: Reg check: Parse string: ( 2:8260762964 )( 1:21 )( 50:0 )( OV:9199 )( BV:9197 )( S:2e836c32c723476727a162235d8313df )
                    0m 01.32s: Reg check: Option check status-Local
                    0m 01.33s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):1:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:0 )-( Blu-ray to Blu-ray:1:0 )-( Blu-ray to Mobile:1:0 )-( File to Mobile:0:0 )-( Blu-ray to DVD:1:0 )-( DVD to Blu-ray:1:0 )-( File to DVD:1:0 )-( File to Blu-ray:1:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:0 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-
                    0m 01.33s: App info: language type ENU.
                    0m 01.34s: App info: Install path C:/Program Files (x86)/DVDFab 9 US/
                    0m 01.34s: Reg check: Start get sys number.
                    0m 01.34s: Export Blu-ray source information report : disabled
                    0m 01.35s: Reg check: Serial number is: a4-17-31-aa-a0-cc:16-17-31-aa-a0-cb:a4-17-31-aa-a0-cb:e0-db-55-d4-23-9a
                    0m 01.35s: Init process: Init GPU settings successful.
                    0m 01.36s: Reg check: Connect type is: 0
                    0m 01.36s: connect plugin info : start.
                    0m 02.08s: Profile Manager :: End Load Profile
                    0m 02.08s: connect plugin info : 1:1
                    0m 02.23s: Reg check: Times of connecting error is: 0
                    0m 02.24s: Reg check: Parse string: ( S:a975ca57cfb3c98b97a6e48cfb826b6f
                    0m 02.28s: Reg check: Option check status-NewWork
                    0m 02.75s: Init preview: Begin init preview play engine.
                    0m 02.75s: Init preview: Begin init preview play engine(Internal).
                    0m 02.89s: Init preview: Init internal engine successful.
                    0m 03.81s: Burn engine: start init.
                    0m 03.82s: Burn engine: set log folder.
                    0m 03.82s: DVD: init read settings.
                    0m 03.99s: DVD: init write settings.
                    0m 04.00s: DVD: DVDInfo_SetDvdrBlocks size = 2201600
                    0m 04.00s: DVD: after DVDInfo_SetDvdrBlocks
                    0m 06.54s: DVD: after SetBurnEngine, Burn Type = 0
                    0m 06.55s: DVD: after init write settings.
                    0m 06.56s: DVD: finish init write settings.
                    0m 06.56s: BD: init read settings.
                    0m 06.57s: BD: init write settings.
                    0m 06.59s: bd set region A
                    0m 06.59s: Burn engine: config engine type-0 begin.
                    0m 06.60s: Burn engine: config engine type-0 end.
                    0m 06.61s: Burn engine: writer count 2.
                    0m 06.62s: Burn engine: 0- D:\ [HL-DT-ST DVD+-RW GU70N A102 (Scsi)].
                    0m 06.63s: Burn engine: 1- F:\ [HL-DT-ST DVD+-RW GX10N A106 (Usb)].
                    0m 06.64s: Burn engine: end init.
                    0m 07.52s: Init process: Init setting page successful.
                    0m 07.52s: QtLog Mode = false
                    0m 07.53s: Show UI Step 2
                    0m 08.11s: Show UI Step 3
                    0m 08.12s: Start show MainUI.
                    0m 08.13s: UI manager: switch to Copy mode.
                    0m 09.50s: Init process: init main ui successful.
                    0m 10.25s: Plugin Info : 1 exits flag = false plugin path = C:/Program Files (x86)/DVDFab 9 US/Plugins\VideoDownload.xml
                    0m 10.34s: Init process: show main ui successful.
                    0m 10.36s: DriveX msg: Init driveX D with I/O mode: 0
                    0m 10.37s: DriveX msg: Init driveX E with I/O mode: 0
                    0m 10.38s: DriveX msg: Init driveX F with I/O mode: 0
                    0m 10.39s: opening drive E
                    0m 10.40s: opened i/o
                    0m 10.40s: failed to get configuration: sensekey 05 asc 20 acsq 00
                    0m 14.25s: got max lba 342015
                    0m 14.32s: got disc type 0
                    0m 14.33s: DriveX msg: add media in driveX E.
                    0m 14.34s: DriveX msg: send open media msg to thread for driveX E.
                    0m 14.36s: opening drive F
                    0m 14.37s: opened i/o
                    0m 14.37s: got media type 4
                    0m 17.05s: got max lba 3111567
                    0m 17.07s: got disc type 10
                    0m 17.16s: type DVD-VIDEO
                    0m 17.17s: volume label NATM_3_SECRET_OF_THE_TOMB
                    0m 17.18s: DriveX msg: add media in driveX F.
                    0m 17.18s: DriveX msg: send open media msg to thread for driveX F.
                    0m 17.19s: opening drive D
                    0m 17.20s: opened i/o
                    0m 17.21s: Source managerpen source flag:1,1,1,1,1
                    0m 17.22s: opening drive E
                    0m 17.22s: opened i/o
                    0m 17.23s: failed to get configuration: sensekey 05 asc 20 acsq 00
                    0m 17.24s: got max lba 342015
                    0m 17.30s: got disc type 0
                    0m 17.31s: Source managerpen source flag:1,1,1,1,1
                    0m 17.32s: Source managerpen source flag:1,1,1,1,1
                    0m 17.34s: Source manager: add source id 0.
                    0m 18.40s: Source manager: open successful.
                    0m 18.41s: UI manager: switch to Copy mode.
                    0m 19.66s: Work manager: create DVD clone work 0 with source 0 and uiinfo 0.
                    0m 19.75s: Source managerpen source flag:1,1,1,1,1
                    0m 19.75s: Source manager: add source id 1.
                    0m 19.86s: Source open statusVD Yes, 2231-10-11
                    0m 19.88s: Source open status:BD Yes, 2158-1-1
                    0m 19.89s: internal path F:/VIDEO_TS/
                    0m 19.94s: got copyright 1 fe
                    0m 19.94s: key method 0
                    0m 20.48s: got udf/iso
                    0m 22.20s: got discinfo
                    0m 22.22s: pathplayer enabled
                    0m 25.19s: button: vts_4 menu_1 pgc_12 cell_1 start_0 end_9963 sector_5964 count_4
                    0m 31.78s: user cancelled
                    0m 31.79s: failed to open 1
                    0m 31.85s: Source manager: open failed, delete source id 1.
                    0m 31.87s: Source managerpen source flag:1,1,1,1,1
                    0m 54.94s: set folder F:/VIDEO_TS/ with type 0
                    0m 54.96s: opening folder F:/VIDEO_TS/
                    0m 54.98s: set folder F:/VIDEO_TS/ with type 0
                    0m 54.99s: opening folder F:/VIDEO_TS/
                    0m 54.99s: Source manager: add source id 2.
                    0m 55.02s: Source open statusVD Yes, 2231-10-11
                    0m 55.02s: Source open status:BD Yes, 2158-1-1
                    0m 55.03s: css attach F:/VIDEO_TS/VIDEO_TS.IFO
                    0m 55.04s: css attach F:/VIDEO_TS/VIDEO_TS.BUP
                    0m 55.04s: failed to open 0
                    0m 57.65s: Source manager: open failed, delete source id 2.
                    0m 57.76s: Source manager: select video files for open.
                    0m 57.77s: opening iso F:/
                    0m 57.77s: Source managerpen source flag:1,1,1,1,1
                    1m 13.61s: Exit process: stop running.
                    1m 13.62s: Exit process: preview pfn_releaseplayer end
                    1m 13.64s: Exit process: preview pfn_deinit end
                    1m 13.66s: Exit process: preview FreeLibrary end
                    1m 13.66s: Exit process: finish MainUI.
                    1m 13.75s: Exit process: finish FreePref.
                    1m 13.75s: Exit process: finish AVEditWrap Release.
                    0m 00.03s:
                      FYI, when I opened the program to get the log for you it was at copy full movie. When I just switched over to it to it, it had changed to clone on its own.
                        Maybe it's caused by the driver E.
                        Is it a Virtual Drive? Did you mout any file in driver E?
                          Drive E is an external dvd drive I plug in because my internal is crap and doesn't work most of the time. It's never given me a problem before; only after the most recent dvdfab update I did last week.
                            That code means "logical unit not supported". Try plugging the optical drive in before starting DVDFab and make sure windows recognizes it and can open a disc if you put one in. I would also suggest not using anything else on the USB controller while doing disc I/O.
                              Thanks, I usually do that but next time I'll wait a minute to make sure everything is working before starting the program. It still wants to go to clone and I am able to switch it after some work, so it is working. I'd just like it to default to the one I use all the time. Thanks for your help and I'll take any other suggestions anyone has.
