Help is currently available only on line. How can I get off-line help? (My Win7 system does not have access to the Internet.)
Also, the current off-line help for version 9 doesn't match version 9.1.5.9. Where can I find up-to-date help?
Also, 'a-user-guide-of-dvdfab9.pdf' lists the ripper settings, but doesn't explain them. For example, there is an H.264 "Encoding Method" called "CRF". What does that mean? What does it do?
So far:
MPEG4 rips play on my computer (MPC-HC), but not on my Panasonic Home Theater.
H.624 rips have no sound or subtitles on my Panasonic Home Theater even though I have sound & subtitles set in the rip.
I have attached the MPEG4 settings files 'MP4.Default.fabpf ...H264.txt' &
'MP4.Default.fabpf ...MPEG4.txt' (the 'txt' extensions were added to keep the forum uploader happy).
Thank you.
So far:
Thank you.
