Here is a link to some info about a similar problem and the use of the VSO convertor read everything here to see if it will help you the info. is older but may help you.
The online manuals I looked at say they didn't play mp-4 and your manual also say's this.If you find that it plays mp4's made using a old non standard codex then that's a bonus but not the norm.
You shouldn't expect it to play and that's my point.I would try converting the files that don't play to something that does play doing so is very fast in most cases.
Hope this helps you.
