nVidia Driver 340.52
    I see that NVidia has released a new Geforce drive version 340.52
    Does anyone know if this fixes the issue with DVDFAb ?
    I wanted to ask the same thing.
    It would be helpful to know just what the "compatibility issues" are, (what symptoms, etc.) as I'm sure there are plenty of folks that would be willing to try the new drivers.
      I hope the QA Team can test it when the office opens.
        Could not enable CUDA in DVDFab V9159 after installing the latest driver version 340.52.
        Test with GTX 750 Ti and GT 560.
        Checking is ongoing...
          Thanks to the QA Staff, sorry it was not better news.
            No CUDA Compatibility with GTX 670 or GTX 770
            I have tested the latest version of DVD Fab on my GTX 670s and GTX 780s and neither of them work. I have been stuck with CPU conversion for months and this is getting ridiculous!
              I am running dual EVGA GTX 780s and it works just fine, it has to be something else in your configuration.
                what ver is the video driver you are using? i have the 340.52 but it does not work on my 640 just software conversions unless i roll back the video driver then all is fine
