I am new to this forum and hope I am in the right forum - I have an issue with DVD Fab's free HD Decrypter. Any help or info would be much appreciated. Many thanks in advance!
I had DVD Fab installed for quite a while and copied a BluRay onto my harddisk. Haven't used it in a while and now needed to copy another BluRay. Not convert it into another format, just copy the main movie onto the harddrive.
I updated it to the current version (9.1.7.6), but when I inserted the BD, it told me I'd have to re-new DVD Fab BluRay Copy.
I thought the HD Decrypter could be used to just copy an HD movie onto the harddrive - and that this is a free module that wouldn't need to be registered?
I also installed PassKey in addition, in case that was needed - it told me I was testing Passkey BluRay, then after inserting the disc said I was using Lite and would need to get BluRay.
What am I doing wrong? How can I ask DVDFab to use the free HD Decrypter instead of BluRay Copy, which seems to have expired?
Thank you again,
best regards,
Chris
Thank you again,
best regards,
Chris
