This is gonna sound stupid but ...
I recently took up the offer to merge my 3 separate copy, rip & convert lifetime to an All-In-One lifetime. (I really recommend anyone to 'not dip a toe in the water' and go the whole hog to buy the All-In-One first off)
I do most of my work on a fairly powerful workstation but it doesn't have a Blu-Ray drive.
I have a lap top with a Blu-Ray ...
Under the old DVD copy you could copy DVD's to DVD9 without a licence
Can you still ? Can you do the same with Blu-Ray's
What I want to do is copy the Blu-Ray, transfer it to my workstation, then continue processing.
(Also, this way I could do copying from one PC and ripping from another, using GBE to transfer
Is this permitted or will it bomb out after 30 days or so ?
Thanks In advance
Mutt
Thanks In advance
Mutt
