Remove watermark with Video Converter?
    License/Key Remove watermark with Video Converter?
    I ripped a bunch of old family DVD's without watching one. Then I watched one and saw the watermark of the monkey ugh.
    I am wondering if anyone knows if I buy the video converter and run them through it, if it will remove the watermark?
    If not, is there a way with one of the products to remove the watermark?
    i believe you would have to re rip the original dvd's
    if you try the already burned dvds the watermark will still be there.
      No way to remove it, you can use the manual cropping controls to chop it out at the expense of large parts of the image.
        Hi Cindil
        october262 is correct you would have to purchase the module you used whether it was the copy or ripper module and redo the process to remove the watermark.
        Registered modules do not have the watermark trial modules do.
        CBR929
          Hi! It's not true! In fact, there are ways to remove watermark from video, we just need some tricks to do it. Maybe it's not that perfect but there are ways to get the similar effect of removing approximately, saying, cropping, replacing watermarks. .
            Yes, there are ways that try and remove watermarks. But none of them are perfect. The only way to really get it right is to purchase the particular module and re-rip.
              No effective way to do it without harming the video content of the Source. Enough about this, thread closed.
