hi,
i have a ripped disk.
it works fine. now i want, just main movie of the disk.
it is john wick, usa version.
powerdvd and procmonitor says the correct playlist is playlist 22.
you say it is 719 or something like that.
it is a playlist obfuscation disk and it is dolby atmos.
i have verified myself that playlist 22 is the correct playlist
by playing pieces of it and
the sequence you wish to select to extract the main movie is the wrong sequence using bdinfo and checking those playlists out.
my question why can't i select playlist 22 when i know it is correct
as the main movie for output?
is there some other way using your tools, to extract playlist 22 from my ripped BDMV folder?
jetli
jetli
