It crashed when it tried to use this Cuda driver. I tried 3 times, same result, DVDFab just exited. It re-encoded okay but took much longer without Cuda.
DVDFab 9.2.3.1 crashes when reencode using Nvida GeForce 940M Cuda
Which driver? I'm using 361.91 and all is well.How to post the internal log
It turns out that Nvida 940M is not the active display adapter, Intel 5200 is; so how to switch to use Nvida instead of Intel?
This is a new Asus UX303UB laptop and it is configured like this. I try to do it from the display setting, but it wouldnt allow me to switch to a different display adapter, only Intel shows up. Under the device manager, both show up.
I would check the BIOS setup and see if the discrete video card can be selected before disabling Intel in device manager.How to post the internal log
My laptop has a button and hotkey to turn the GPU on or off (switch from Intel to GPU), maybe yours does also. May be hard to find. Mine was poorly marked.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
I talked to Asus, they said that there is no botton to toggle between GPUs.
From the bios, there is no information about GPU or even SSD or HD. So the only option is probably to disable the Intel Graphics from Device Manager, but that is risky since if Nvidia doesnt come up, then there would be no display???
I play around with Nvida Control Panel, under Manage 3D settings, Global Settings, I switch it to High-perforance Nvidia processor. Under Set PhysX Configuration, it is set to GeForce 940M. I even change Program Settings to use global setting (High-performance Nvidia processor) for DVDFab 9, but that doesn't work either, DVDFab crashes as soon as it starts to re-encode.
Here is System information for my 940M:
NVIDIA System Information report created on: 02/28/2016 01:20:07
System name: DESKTOP-562D0BL
[Display]
Operating System: Windows 10 Home, 64-bit
DirectX version: 12.0
GPU processor: GeForce 940M
Driver version: 361.91
Direct3D API version: 12
Direct3D feature level: 11_0
CUDA Cores: 384
Core clock: 1071 MHz
Memory data rate: 1800 MHz
Memory interface: 64-bit
Memory bandwidth: 14.40 GB/s
Total available graphics memory: 8141 MB
Dedicated video memory: 2048 MB DDR3
System video memory: 0 MB
Shared system memory: 6093 MB
Video BIOS version: 82.08.3B.00.4B
IRQ: Not used
Bus: PCI Express x4 Gen3
Device Id: 10DE 1347 1B1D1043
Part Number: 2701 0005
[Components]
NvUpdtr.dll 2.10.2.40 NVIDIA Update Components
NvUpdt.dll 2.10.2.40 NVIDIA Update Components
NvGFTrayPluginr.dll 2.10.2.40 NVIDIA GeForce Experience
NvGFTrayPlugin.dll 2.10.2.40 NVIDIA GeForce Experience
nvui.dll 8.17.13.6191 NVIDIA User Experience Driver Component
nvxdsync.exe 8.17.13.6191 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.13.6191 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.13.6191 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.13.6191 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.13.6191 NVIDIA User Experience Driver Component
nvCplUIR.dll 8.1.820.0 NVIDIA Control Panel
nvCplUI.exe 8.1.820.0 NVIDIA Control Panel
nvWSSR.dll 6.14.13.6191 NVIDIA Workstation Server
nvWSS.dll 6.14.13.6191 NVIDIA Workstation Server
nvViTvSR.dll 6.14.13.6191 NVIDIA Video Server
nvViTvS.dll 6.14.13.6191 NVIDIA Video Server
nvDispSR.dll 6.14.13.6191 NVIDIA Display Server
NVMCTRAY.DLL 8.17.13.6191 NVIDIA Media Center Library
nvDispS.dll 6.14.13.6191 NVIDIA Display Server
PhysX 09.15.0428 NVIDIA PhysX
NVCUDA.DLL 6.14.13.6191 NVIDIA CUDA 8.0.10 driver
nvGameSR.dll 6.14.13.6191 NVIDIA 3D Settings Server
nvGameS.dll 6.14.13.6191 NVIDIA 3D Settings Server
