Dvdfab won't open hunger games
    I have the newest version of DvdFab but it won't open the bluray US version of Hunger Games: Mockingjay part 2, It keeps coming up that DvdFab has experienced a problem and needs to close, But it works fine for DVDS.
    What version do you use?
    http://www.dvdfab.cn
      9235, Just got it this morning.
        Please post internal log, thanks.
          Is this what you want.
          File Size
          crashdump.dmp 263067.KB
          errorlog.xml 205 .KB
          Osprocess.txt 775.KB
          screenshot.bmp 2871.KB
          burn_vso.log 3 .KB
          dvdfab_internal.log 55 .KB
          fabcheck.internal.log 9 .KB
          pathplayer.log 18 .KB
            Jimmy
            We need the DVDFab internal log session from this disc. The instructions for supplying it are linked in my sig, below. This disc should be fully supported unless you have a different version. The log will tell us that. The session for this disc will be near the end of the log.
              Mockingjay pt.2
              I get the same message as Jimmy56, after it crashes, it says DVDFab has encountered a problem and needs to close. I can't get to the internal log.
                The single disc version of this title is not supported yet, should be soon. Don't post questions about specific discs in this forum, use DVD or Bluray Copy forums instead, we can then tell which you have without playing 20 questions. The retail combo pack is fully supported, DVD and Blu-ray.
                  Sorry, Just noticed I posted in wrong section, And Thank you for the information.
                    The single disc version of this title is not supported yet, should be soon, That should be stated in the change log so people would know.
                      It was not known at the time. When you quote something someone else has said, use the quote button or the quote BB code. You remind me of someone else that used to do that.
                        Just noticed I did that, But was using that sentence when I was making a statement.
                          I also can not unlock MockingJay2. I have the latest software but it just automatically closes passkey after it analyizes the program. Here is the log:
                          DVDFabPasskey 8.2.6.6 (2016/03/26 06:49:10)
                          0m 04.88s: opening drive K
                          0m 04.88s: opened i/o
                          0m 04.88s: got media type 15
                          0m 05.36s: got max lba 12953759
                          0m 06.24s: got disc type 20
                          0m 06.24s: type Blu-ray BDMV
                          0m 06.24s: volume label MOCKINGJAY_2
                          0m 06.24s: bd set region ?
                          0m 06.25s: internal path K:/BDMV/
                          0m 06.48s: aacs 1 bd+ 0
                          0m 06.84s: got bdmv
                          0m 11.23s: got agid 0
                          0m 11.24s: sent host cert chal
                          0m 11.24s: got drive cert chal
                          0m 11.24s: BEC 1
                          0m 11.24s: DRIVE_VENDOR 0x0074
                          0m 11.26s: got drive key
                          0m 11.38s: got host key signature
                          0m 11.38s: verified drive signature
                          0m 11.38s: verified host signature
                          0m 11.40s: sent host signature and key point
                          0m 11.40s: got bus key
                          0m 11.40s: got volume id
                          0m 11.40s: got volume id mac
                          0m 11.40s: volume id is correct
                          0m 11.40s: got vid
                          0m 11.51s: blu-ray DFBB8843538F3EE57E8E473540A30881F8A0D3A5
                          0m 11.99s: cert BEE=0x80 same
                          0m 12.37s: D A0B0CF58
                          0m 12.37s: main playlist 00821.mpls
                          0m 12.37s: selected region A
                          0m 12.37s: bd set region A
                          0m 12.37s: detected cinavia
                          0m 12.37s: got vuk
                          0m 12.38s: got agid 0
                          0m 12.40s: sent host cert chal
                          0m 12.40s: got drive cert chal
                          0m 12.40s: BEC 1
                          0m 12.40s: DRIVE_VENDOR 0x0074
                          0m 12.40s: AACS bus encryption is enabled
                          0m 12.41s: got drive key
                          0m 12.41s: got host key signature
                          0m 12.41s: verified drive signature
                          0m 12.41s: verified host signature
                          0m 12.44s: sent host signature and key point
                          0m 12.44s: got bus key
                          0m 12.44s: got data key
                          0m 12.44s: got unit key 4
                          0m 12.44s: blupath: movie disc
                          0m 13.29s: StealthyClone with BluPath
                          0m 14.55s: Java protection is removed by StealthyClone anti-protection.
                          0m 14.55s: full disc copy/play may not be supported yet: 45 or blupath failed to check that
                          0m 14.96s: got bdmv
                            Mockingjay2
                            0m 06.84s: got bdmv
                            0m 11.24s: BEC 1
                            0m 11.40s: got vid
                            0m 12.37s: got vuk
                            0m 12.40s: BEC 1
                            0m 14.96s: got bdmv
