DVDFab suite crashes every time on startup
    Other DVDFab suite crashes every time on startup
    Hi
    Since 2.4 i cant run dvdfab anymore. Everytime i start it, it crashes, no error mess, nothing it just crashes. Im sitting on win 10 pro x64
    RIGG:
    Asus Rampage V Extreme
    Core i7 5960X
    2x GTX 1080 SLI
    SSD
    please help.
    Try checking your Antivirus / Spyware software and your firewall
    To make sure that none are blocking dvdfab from starting properly.
    Also make sure that you are running dvdfab " as administrator "
    And please post the dvdfab internal log files.
      iver tried it all. reinstalling like 5 times, run as admin, close AV+FW, compability mode win7, 8, nothin works. Is there no helpdesk or helpchatt? ive paid 300 bucks for a lifetime license, and i cant even use it. where do u find that log file?
        Look under c: my documents folder- dvdfab10
        does dvdfab show up when you start task manager. try checking for a driver update for your computer's graphics card.
        Restart your computer in safe mode and see if dvdfab will Run.
          its the same thing. ive uninstalled it with uninstall tool that cleans all residual files. reinstalling. booting in safe mode. same thing happens, i see the spalsh screen with the version number and the logo, but then windows say unexpected error and it closes.
          i have the latest GPU driver, latest codecs and windows up to date.
            When you start dvdfab, does it show up in task manager ??
              no :/
                ive tried everything twice.. it does not work. what do i do?
                  Well big boy, you need to attach the DVDFab suite of logs, all of them including the install log. Put them in a zip or rar if the forum says they are too large to attach.
                    HEY, im not fat, only a bit husky ok ill fix and upload as soon as i have tried one last thing
                      i got help from staff. thnx anyways.
                        What turned out to be the issue ??
                          some setting in a config file that apparently said to the installer that i dont want the internal video viewern. so startup crashed when no extern viewer was available, im not to sure, i installed a program and then they had full controll over my pc. i sat back and watched the mouse cursor do whatever. But in the end it was a 0 that should have been a 1.
