I have recently made several blocks with Windows Firewall.
Most are related to "Remote Access" but some other areas as well.
None are purposely set to block DVDFab forum.
If I knew the port or ports this forum uses for downloading attachments I could allow DVDFab forum through.
Or I believe I could.
This has also caused "Live Update" not to work for DVDFab software.
I now get a completely white screen for the "Live Update" window.
So I also need to know the port DVDFab uses for this.
I haven't tested this for Passkey as I believe I have the latest official release installed.
I haven't tried a manual download & install.
I already have 10.0.5.7 installed. I usually only install official releases & not betas.
That is what I plan to keep doing.
When version 10.0.5.8 has an official release I will try a manual install with it.
Then post if this works.
I just found another problem.
Using DVD Ripper . When finished the window in front of the DVDFab task Manager was all white.
I had to hard close the DVDFab task manager with Window Task Manager.
This also closed the DVDFab GUI.
The conversion was complete & worked.
