Merging 3 dvds to 1
    Merging 3 dvds to 1
    I have version 8.2.2.9 and need to combine into one dvd the shows from 2 different dvds. Do I merge, how do I merge? Please help.....Thank you.
    Merge mode is what you would use to do this, but there are practical limits as to how many you can Merge in terms of size. If you exceed the size of a SL or DL DVD blank, the video will be compressed to fit. This is fine up to a point, but the quality starts to suffer if you try to squeeze too much into the merged volume.
    Please update to one of the current versions, it would be difficult to help you with v8 since it is no longer supported.
      Hello Signals,
      Thank you for getting back to me with my issue. I think I was trying to merge too much onto a 240 minute DVD. I'll probably just burn one at a time. Have a great day and again, thank you for your help. I will d/l the newest version and go from there.
