Varbatim
    Varbatim
    Hey can anyone help DVDFab wont write to my DVD discs im using verbatim x16 dvd +r keeps saying not writable.
    femsue need more information please post logs The default location is:
    C:\Documents and Settings\User Name\My Documents\DVDFab\Log.
      Can't help you with DVD Decrypter. I assume you meant DVDFab.
        If you are using the free version of DVDFAB it will not write, you will have to have another program to write unless you buy the program then it will read, shrink if needed then write
        Paid Not To Work
        US Navy Retired ( 20 Years )
        Proudly Served On
        USS Coral Sea CVA-43 (VF-154) / USS Oriskany CVA-34 (VFP-63) / USS Ranger CVA-61 (VF-121)
        6 trips to the Gulf Of Tonkin
          Verbatim
          It has been paid for I didnt have a problem then it just stopped writing to the disks.
            You need to post some info for us to help you. Have you tried any other media? Or just when you changed to these. I use the same media and no problems to share.
              It also has been 21 days since your last post at that rate it will take years to figure this out.
              03.04.10 to 03.25.10
                Post the logs. You can just attach them to a post using the manage attachments button.
