I need help figuring out how to write BD-RDL media. I have tried multiple types of media, drives, everything I can think of. Started with a LG WH16NS40 and the disc that came with it. Don’t remember what they were. I have used the DVDFab Burning Engine at every write speed. I have tried using Imgburn at all speeds (mostly at half disc rates speed). Replaced the LG drive with an Asus ASUS BW-16D1HT. Also got a replacement LG WH16NS40. Sometimes the write would complete but the disc has issues when played in a BD player. I switched on the option “Verify disc when burning finishes”. This pretty much has never worked using the DVDFab Burning Engine. Most of the time it will just hang at the end of finalizing. Sometime it will start to verify if you manually open and close the drive. Usually this will just crash DVDFab. Imgburn will log read or write errors. I probably have many logs if that is helpful.
These are the media types I have now: VERBAT-Imf-000, CMCMAG-DI6-000, RITEK-DR2-000.
With all the options available, there has to be some combination that will successfully write a BD DL disc. Any help is appreciated, there has to be a better way to troubleshoot that wasting discs.
