How do I burn an ISO file to DVD?
    I have some dvds in *.iso format and can't figure out how to use DVDFab to burn them to a DVD. Can anyone help please!
    Thanks
    MammaMia
    Select the write data mode and then click the img icon beside the source dropdown, find your .iso and click start.
      This is what I would do. Download ImgBurn and VirtualCloneDrive. Mount the .iso file as a drive. Use ImgBurn to write to DVD media. Simple.
        Why would you even mount the iso if you know how to use ImgBurn? Like doing things the hard way
          W&B, good call. Too many different apps to keep up with. Just ImgBurn it.
            Agree with W&B.
            Just to clarify you'll need to open the .ISO file.
            (I'm pretty sure it was a typo in his first post although he may have wanted you to use Img as the burn engine as well).
            On the opening screen, note the Source box...to the right, note the .ISO icon to the far right. This looks like a dog-eared page with the disc overlay.
            Click on this and navigate in windoz to the location of your .ISO file.
            Sometimes a picture's worth a 1000 words
            Here's a screenshot:
              We recommend DVDFab Virtual Drive.
