Simple Feature STILL Isn't Fixed
    I've been using DVDFab since version 5 but version 7 has yet to fix a simple feature that 5 & 6 had and worked.
    In the Target dropdown, I would like that to remember my setting each time I re-open DVDFab. If I set it to a folder instead of a DVD drive, that's what I want to see when I re-open DVDFab as my Target. In version 5 & 6 this worked fine. It's never worked in version 7.
    I've uninstalled, reinstalled, and re-entered my reg key several times but it still doesn't work. This feature is very simple to code (about 2 lines) and should be one of the easiest features to make work but in version 7 I've never seen it work even with "Memorize user interface options" checked or unchecked.
    Very frustrating.
    Works for me on Windows 7 64bit.
      Also, works for me on XP SP3 & Win 7 64 bit.
        Works at this end also.
        Win XP pro SP3
          Set the default output type to "DVD Folder" in Common Settings->DVD to DVD. It works as it has for me also, Win7/64 and XPSP3.
            Works for me too, on both rigs...Win 7 Pro 64-bit and XP Pro 32-bit.
            Strange, not the first time we've seen different behavior with the same rig and Fab 7
              Setting default to DVD Folder seems to have fixed it. Never had to do that before but thanks for the help.
                Glad to hear signal's suggestion worked for you
