I just got a new computer and this is the first time I've had a DVD drive, anyway I haven't inserted any dvds in because
I know there is a drive lock, I can only change it 5 times
and the majority of my movies are Region 4 but my TV series boxsets are in Region 1 (cuz I find it cheaper to preorder them online from the US than wait for them to come out here Down Under and they mostly cost more)
I don't plan to burn/back them up just yet because I have no blank discs (I wouldnt know where to start on which ones to buy,
I'm such a newb)
I would like to for the meantime back them up on my drive, if that is possible I think it is, something I read about an 'image file'...?
My question is when I insert a dvd disc do I have to set the region code for my drive? And if I do, do I only have to change it once even if the disk I insert the same region? (I assume I would have to change it if I insert a different region disc)
I've turned off disc-auto play, I only have 5 turns to change and then it locks, I'm confused but DVDFab can work in the background or bypass or something right?
I just dont want my drive to lock on me, help would be appreciated, I feel so thick for not understanding the tutorials and posts in here...
Thank you in advance!
I'm such a newb)I would like to for the meantime back them up on my drive, if that is possible I think it is, something I read about an 'image file'...?
- Benjamin Franklin 1706-1790
