NO Codecs Detected, NO CUDA w/ NVIDIA 8800 GTX
    CPU/GPU NO Codecs Detected, NO CUDA w/ NVIDIA 8800 GTX
    I had another PC sitting around that used to be my old gaming machine.. It is a XFX nForce 780i 3way SLI motherboard and has 3x Nvidia 8800GTX video cards in it.. I tried SLI and Non-SLI modes, enable / disable the physics settings, using latest drivers, Even installed the pay version of CoreAVC.. But no matter what, this is all that DVDFab ever says for this machine.
    "Graphics Chipset :
    NVIDIA GeForce 8800 GTX
    Supported Video Codecs :
    CoreAVC : is detected."
    So - no supported Vide3o Codecs, no CUDA, can't set DirectX accleration or any hardware encoding..
    This machine is a intel quad core 2 machine.. with 8 gigabytes of DDR2 ram..
    Any suggestions? Everything else on the machine seems to work fine..
    -D2G
    What driver do you have for this card?
    sigpic
      Version: 257.21 WHQL
      Release Date: 2010.06.15
      Operating System: Windows Vista 64-bit, Windows 7 64-bit
      Language: English (U.S.)
      File Size: 124 MB
      Download drivers for NVIDIA graphics cards, video cards, GPU accelerators, and for other GeForce, Quadro, and Tesla hardware. US / English download.
      Using Win7 64bit OS..
      Let me know if you need any other information!
      - D2G
        Unless you are hard core gamer and using card for gaming, I would NEVER suggest to use beta drivers. Stable programs like stable drivers. Please roll back to last stable one (I believe it's 197.45), clean registry and try again.
        However, this is third complaint (known to me) on this forum in regards to 8xx series of nVIDIA cards in relation to CUDA.
        sigpic
          Hmm. These were official release, non-beta drivers.. and we wanted to make sure to get these in order to get benefits of full hardware acceleration flash 10.1, etc.
          and it is a 3x SLI system... So yah - gamer - I'll pull those other drivers and see if that solves the situation. I also have a dual SLI 9800 GTX system here I'm going to give it a whirl on to see if it works there..
          Thanks for the feedback!
          -D2G
            -D2G
            Please read these two, most recent threads. You may find some of it useful
            Please let me know if I could be any more helpful for you.
            sigpic
              Finally got back to this system to test other versions of the Nvidia Drivers. I have gone back all the way I could for windows 7 64bit and tested every release driver up to the latest version and NONE of them will show any codec support or cuda support for this card / system in DVDfab :S
              - D2G
                Try disabling SLI. Some of the others with this problem were using it.
