I was just wonder if I was to add a SSD to my current machine as OS drive and rip drive. Would that increase my rip time? It's currently taking a average of 3 to 4 hrs for a main movie BD9 1080P.
Solid State Drives
Other Hardware Solid State Drives
Homebrew Win 724X DVD BLU-RAY 4X COMBO AMD Athlon II X2 2.9GHz Dual-Core ASUS M4A785-M 750GB 7200 RPM G.SKILL 4GB DDR2 SDRAM
Display: 50 LG Plasma 720P 600hz HDMI
Mac Mini 09 Intel Core 2 Duo 2.26 GHz Dual-Core2 GB DDR3 SDRAM Eyetv Hybird
Display: 42 LCD Philips 1080P 60hz HDMI
Network DIR-655 Router HP Media Smart Server LX-195 DNS-321 Storage 5+ TBTags: None
I don't think it would make a big difference. For a dual core without GPU acceleration, 3-4 hours is not too bad.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
How do I know if I got GPU acceleration or not?Homebrew Win 724X DVD BLU-RAY 4X COMBO AMD Athlon II X2 2.9GHz Dual-Core ASUS M4A785-M 750GB 7200 RPM G.SKILL 4GB DDR2 SDRAM
It depends on your video card. You can check to see if DVDFab supports it by clicking on the little checkmark in the upper right corner of the DVDFab window. Then click on "A/V Codec" in the left window. You should see something like the attached image that shows if DVDFab recognized anything. If it did, it will be listed in the large text box. Hope for CUDA.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Originally posted by GregiBoy View PostHere in Oz, I cannot see the cost effectiveness just yet.
240Gb SSD = AU$890
1Tb SATA = AU$83
I think I'll be waiting a while......
Besides, being an old fart, I am surrounded by too many things much faster than me already...If it ain't broke, don't fix it!
Originally posted by DharmaBummed69 View PostYou know how it is with new tech. They really make you bend over for it at the register the first few it's out.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
extrememc,
take a look at this thread:
I did it 'cause I could. In general. I wouldn't recommend to spend this kind of money for such a mediocre improvement.
Originally posted by extrememc View PostI was just wonder if I was to add a SSD to my current machine as OS drive and rip drive. Would that increase my rip time? It's currently taking a average of 3 to 4 hrs for a main movie BD9 1080P.sigpic
