Do I need to pay again?
    I'm a registered user of 5.0 and just downloaded the 7.0. I've read through the registration problem post and neither of those methods are allowing me to get registered.
    Do I need to uninstall 5.0?
    Should I re-install 7.0 in the same directory as 5.0?
    Any help is appreciated. Thank you
    You need do download a new key if your registration has nor run out.
      You can get the v6/7 key here:
      It is free if your license has not expired.
        I got a new key. How can I tell if my license has expired?
          Click on the "?" green button, top right then "About"
            Sorry to be such a pain but I checked my license and it was expired. So I renewed for two years. I uninstalled and re-installed 7.0. It is still showing my old expiration date.
              You need to retrieve your new key and follow the steps in the "Registration Key Problems" thread EXACTLY !!!
                Got it ! Thank you for your help.
                  Hi Ray,
                  Glad it all worked for you.
                  Hope we see you as a regular visitor and contributor on the forum.
                  Best Regards
                  GB
