Hello all.. just recently found DVDfab.. seems I have missed out on some great deals if I had learned about and bought it a few years ago!
Anyway, I've tried looking around for this answer but don't see anything straightforward. Sorry for being such a noob...
I am ONLY looking to copy our DVD's to our Tivo for convenience for the kids (and so they stop ruining the discs!) ... All I need is the DVD-to-Mobile option.
When I go to purchase it, however, and uncheck everything else, it indicates:
Which I find very confusing.. Because on the home page (), "DVD-to-mobile" is listed as "Other DVDfab Products" rather than as "Add-Ons"... And on DVD-to-mobile's homepage () it indicates the cost is $30.
So I'm really confused... can I just buy the DVD-to-Mobile like I need, or do I really need to buy both DVD-to-DVD *and* DVD-to-Mobile?
ALL I need is mail-title VOB copy... And unfortunately I'm on a very limited budget. I can do DVD-to-Mobile for $30 ... but doing both packages pushes it over $80... WAY past my budget...
thanks *soooo* much,
..dane
Note:
DVDFab "DVD to Mobile" works with DVDFab "DVD to DVD" together. That is, you MUST have a valid DVDFab "DVD to DVD" license, which is applied to the same e-mail address. Please get the two products together. Otherwise, you can always retrieve the keys here, to make sure if you already have a valid license.
..dane
