Need Help - Optical Drives Will Not Recognize BD 50 Discs As Writable Media
    I am trying to back up some 3d Blu-ray movies. I copied the movies to my hard drive saving them as ISO files. I loaded the ISO file into DVD Fab and selected BD50 as output.
    Now none of my (3) optical drives will recognize these discs as writeable media. I have tried discs from 3 different spindles – DVD Fab will not recognize any of them as writeable media.
    I am using Optical Quantum BD-R DL 50 GB Discs. I have used these discs many times in the past with great success. The last time I used these discs to back up a 3d movie was with release 10.2.1.4 / 64.
    Has something changed in the later releases of DVD Fab that is preventing me from using these discs?
    Thanks you in advance for your help.
    Mark
    Not to my knowledge. Please attach the DVDFab internal log and DVDFab burn log.
      Sorry for the late reply. I did not see where anyone has answered me. Not really that computer savy but I'll try and upload the files you requested.........
      (12/12/2021) Tried to upload the files but am getting messages that the files are too large - can't even send a screen shot of the log directory. Not sure what to do next - still have the problem - can't burn any blu rays, but I can read previously burned blurays.
      Thanks for your help.
      Mark
        Hi Signals. Since I can't upload the files you requested will the following be of any help?
        dvdfab_internal (partial)
        DVDFab 12.0.5.5 (2021/12/12 19:31:00) (X64)
        2021.12.12-19:31:00 (8756): Init Public log: enabled.
        2021.12.12-19:31:00 (8756): Init Private log: finish.
        2021.12.12-19:31:00 (8756): App info: 2021-12-1
        2021.12.12-19:31:00 (8756): App info: 12.0.5.5 12055 Official
        2021.12.12-19:31:00 (8756): Init CrashReportSettings: enabled.
        2021.12.12-19:31:00 (8756): Init DVDInfo_Log: enabled.
        2021.12.12-19:31:00 (8756): app info: compiled time Dec 1 2021 14:57:34
        2021.12.12-19:31:00 (8756): code page is 0
        2021.12.12-19:31:00 (8756): app args: count 1,arg 0:C:\Program Files\DVDFab\DVDFab 12\DVDFab64.exe,
        2021.12.12-19:31:00 (8756): Init Qt_Log: disabled.
        2021.12.12-19:31:01 (9720): Profile Manager :: Begin Load Profile
        2021.12.12-19:31:01 (8756): SUCCEED: IServerService WebServer Init succeed.
        2021.12.12-19:31:01 (8756): SUCCEED: IServerService MediaLibrary Init succeed.
        2021.12.12-19:31:01 (8756): DVDFab Qt Translator file load success
        2021.12.12-19:31:01 (8756): App info: client type 58.
        2021.12.12-19:31:01 (8756): MobilePlay load: preload successful.
        2021.12.12-19:31:01 (8756): MobilePlay load: Load successful.
        2021.12.12-19:31:01 (8756): Init process: Transfer settings successful.
        2021.12.12-19:31:01 (8756): info: check logpath= C:/Users/Finne/Documents/DVDFab/DVDFab12/Log/
        2021.12.12-19:31:01 (8756): info: _check_gpu is running ...
        2021.12.12-19:31:01 (8756): info: check_gpu run successful
        2021.12.12-19:31:01 (8756): info: recommand= 202178560, Shrink support= 1, enable= 1, cuda_cap= 0 , cpu_count= 4
        2021.12.12-19:31:01 (8756): GPU check: GPUAccelerate-0XC0D0005
        2021.12.12-19:31:01 (8756): GPU check: GPUAccelerate setting-0XC0D0000, 0XC0D0000
        2021.12.12-19:31:01 (8756): GPU check: CUDA cap-0X0
        2021.12.12-19:31:01 (8756): GPU check: Support coreavc decode-0
        2021.12.12-19:31:01 (8756): GPU check: Lighting shrink status-1, 1
        2021.12.12-19:31:01 (8756): GPU check: Graphics info 1: Intel(R) HD Graphics 630 : 22.20.16.4735 : 24,9 : 1G
        2021.12.12-19:31:01 (8756): Init process: Load config successful.
        2021.12.12-19:31:01 (8756): Server check: Set current server 0.
        2021.12.12-19:31:01 (8756): Init process: Windows os type is 64bit System Windows 10 Build 19043.
        2021.12.12-19:31:01 (8756): Init process: appUuidForLastRun=3330e422-a6ac-430b-b172-22390675c226, appUuidForThisRun=ebabf0c3-9eb1-4bee-97f3-ec7a2b39fc63
        2021.12.12-19:31:01 (8756): Init process: command line in is
        2021.12.12-19:31:01 (8756): ShowStartupDialog: true
        2021.12.12-19:31:01 (8756): Start get hd.
        2021.12.12-19:31:01 (8756): hd1.
        2021.12.12-19:31:02 (8756): hd2.
        2021.12.12-19:31:02 (8756): hd3.
        2021.12.12-19:31:02 (8756): hd4.
        2021.12.12-19:31:02 (8756): hd: e10a18f1ef47eb11400686a617a1c40c-b1bffccfdda4a2f1b9a55cdcddf7b9bf-ce03b1a03b6643c5022a1cc4790f1155-a50b92c9a8e9c833587a7e663c7ddd43-c5e5806341f886fdb2ae6a7b3120601c
        2021.12.12-19:31:02 (8756): Option check status-L
        2021.12.12-19:31:02 (8756): ER( HD Decrypter:1:0 )-( DVD to DVD (Gold):1:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:1 )-( Blu-ray to Blu-ray:1:1 )-( UHD to Blu-ray:1:0 )-( Blu-ray to Mobile:1:0 )-( File to Mobile:0:0 )-( Blu-ray to DVD:1:0 )-( Blu-ray to UHD:1:0 )-( DVD to Blu-ray:1:0 )-( File to DVD:0:0 )-( File to Blu-ray:1:0 )-( File to Blu-ray UHD:1:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:0 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-( CinaviaRemoval HD:1:0 )-( DVD Cinavia Removal:1:0 )-( Blu-ray Cinavia Removal:1:0 )-( UHD Cinavia Removal:1:0 )-( DRM Removal:1:0 )-( iOS Recorder:1:0 )-( UHD Drive Tool:0:0 )-( Hi-Fi Audio Converter:1:0 )-( UHD Copy:1:0 )-( UHD Ripper:1:0 )-( Blu-ray Recorder Copy:1:1 )-( Blu-ray Recorder Ripper:1:0 )-( 4K Recorder Copy:1:0 )-( 4K Recorder Ripper:1:0 )-( Enlarge AI:1:0 )-( Smoother AI:1:0 )-( Media Recover for DVD:1:0 )-( Media Recover for BD:1:0 )-( DVDFab Player6:1:0 )-( DVDFab Player6:1:0 )-( Photo Enhancer AI:1:0 )-( Video Enhancer AI:1:0 )-( YouTube to MP3:1:0 )-( Video Downloader:1:0 )-( DRM fownloader:1:0 )-( Youtube Video Download:1:0 )-
        2021.12.12-19:31:02 (8756): App info: language type ENU.
        2021.12.12-19:31:02 (8756): App info: Install path C:/Program Files/DVDFab/DVDFab 12/
        2021.12.12-19:31:02 (8756): Start checking run condition!
        2021.12.12-19:31:02 (11600): Start check: begin
        2021.12.12-19:31:02 (8756): IUtilityServiceAdatper: Initialize IUtilityServiceDataStats.
        2021.12.12-19:31:02 (8756): Init process: Set account info to DriveX.
        2021.12.12-19:31:02 (8756): Export Blu-ray source information report: enabled
        2021.12.12-19:31:02 (8756): Init process: Init GPU settings successful.
        2021.12.12-19:31:02 (9720): Profile Manager :: End Load Profile
        2021.12.12-19:31:02 (8756): IUtilityServiceAdatper: Initialize IUtilityServiceProductManager.
        2021.12.12-19:31:02 (8756): Burn engine: start init.
        2021.12.12-19:31:02 (8756): Burn engine: set log folder.
        2021.12.12-19:31:02 (8756): DVD: init read settings.
        2021.12.12-19:31:02 (8756): DVD: init write settings.
        2021.12.12-19:31:02 (8756): Init BurnLog : file(C:/Users/Finne/Documents/DVDFab/DVDFab12/Log/burn_internal.log)
        2021.12.12-19:31:02 (8756): BD: init read settings.
        2021.12.12-19:31:02 (8756): BD: init write settings.
        2021.12.12-19:31:02 (8756): bd set region A
        2021.12.12-19:31:02 (8756): Burn engine: config engine type-3 begin.
        2021.12.12-19:31:02 (8756): Burn engine: config engine type-3 end.
        2021.12.12-19:31:02 (8756): Burn engine: start get writer count
        2021.12.12-19:31:02 (8756): Burn engine: writer count 3.
        2021.12.12-19:31:02 (8756): Burn engine: 0-H:\ [PLEXTOR BDDVDRPX-B310U].
        2021.12.12-19:31:02 (8756): Burn engine: 1-F:\ [PLEXTOR BDDVDRPX-B310U].
        2021.12.12-19:31:02 (8756): Burn engine: 2-D:\ [HL-DT-ST DVDRAMGUE1N].
        2021.12.12-19:31:02 (8756): Burn engine: end init.
        2021.12.12-19:31:02 (8756): ShowStartupDialog: false
        2021.12.12-19:31:02 (8756): QtLog Mode = false
        2021.12.12-19:31:02 (8756): Show ProductsInfo Dlg 2
        2021.12.12-19:31:02 (11600): Get cinavia info,(0,1)
        2021.12.12-19:31:02 (11600): Serial number is: 94-b8-6d-80-4e-e5:98-ee-cb-82-a3-4d
        2021.12.12-19:31:02 (11600): Connect type is: 0
        2021.12.12-19:31:03 (11600): Times of connecting server is: 0
        2021.12.12-19:31:03 (11600): FabAuthorize: CheckOption - success
        2021.12.12-19:31:03 (11600): Option check status-N
        2021.12.12-19:31:03 (11600): Server check: update share memory to 0.
        2021.12.12-19:31:03 (11600): Start check: end
        2021.12.12-19:31:04 (8756): Start show MainUI.
        2021.12.12-19:31:04 (8756): dpi scale: x scale 1.000000, y scale 1.000000
        2021.12.12-19:31:04 (8756): dpi scale: real scale 1.000000
        2021.12.12-19:31:04 (8756): dpi scale: system real scale 1.000000
        2021.12.12-19:31:04 (8756): dpi scale: IsHighDpiMode(for mac) false
        2021.12.12-19:31:04 (8756): Init process: init main ui successful.
        2021.12.12-19:31:04 (8756): Guide: SetGuideMode E_GuideType_Copy
        2021.12.12-19:31:04 (8756): UI manager: switch to Copy mode.
        2021.12.12-19:31:04 (8756): View Page showed.
        2021.12.12-19:31:04 (8756): Init process: show main ui successful.
        2021.12.12-19:31:04 (8756): Cinavia Version : 1.346.2.105.1.28
        2021.12.12-19:31:04 (8756): scene data: delete file C:/Users/Finne/AppData/Roaming/DVDFab/DVDFab12/SceneData/38dc9232-bd4d-45f9-8872-1847c7b10d98.SceneData.xml result=0
        2021.12.12-19:31:04 (8756): scene data: delete dir C:/Users/Finne/AppData/Roaming/DVDFab/DVDFab12/SceneData/38dc9232-bd4d-45f9-8872-1847c7b10d98 result=0
        2021.12.12-19:31:04 (8756): before exec()
        2021.12.12-19:31:06 (5504): End Load playcore dll
        2021.12.12-19:31:06 (10580): Enlarger AI: Local enlarger AI plugin, ai_version(no version), app_version(12055)
        2021.12.12-19:31:06 (10580): Enlarger AI: Checking new version for ai dll.
        2021.12.12-19:31:06 (10580): Enlarger AI: plugin id is PreviewEnlarger_fab_win64
        2021.12.12-19:31:06 (10580): connect plugin info: start.
        2021.12.12-19:31:06 (4000): DriveX msg: Init driveX D with I/O mode: 0
        2021.12.12-19:31:06 (4000): DriveX msg: Init driveX F with I/O mode: 0
        2021.12.12-19:31:06 (4000): DriveX msg: Init driveX H with I/O mode: 0
        2021.12.12-19:31:06 (8756): opened i/o type 2
        2021.12.12-19:31:06 (8756): opening drive D
        2021.12.12-19:31:06 (8756): currentProfile: 0
        2021.12.12-19:31:06 (8756): got drive Inquiry!
        2021.12.12-19:31:06 (8756): drive Inquiry!
        2021.12.12-19:31:06 (8756): Drive Version: D, 1.00
        2021.12.12-19:31:06 (8756): got firmware HL-DT-ST DVDRAM GUE1N 1.00.
        2021.12.12-19:31:06 (8756): Source manager: open source flag:1,0,1,1,1
        2021.12.12-19:31:06 (8756): opening drive F
        2021.12.12-19:31:06 (8756): Drive Version: F, 1.07
        2021.12.12-19:31:06 (8756): got firmware PLEXTOR BDDVDR PX-B310U 1.07.
        2021.12.12-19:31:06 (8756): opening drive H
        2021.12.12-19:31:06 (8756): Drive Version: H, 1.07
        2021.12.12-19:31:06 (11104): GetAd Info From server success(1101).
        2021.12.12-19:31:07 (10580): connect plugin info: 1000:1
        2021.12.12-19:31:07 (10580): Enlarger AI: Get enlarger AI plugin info success, ai_version(1048), app_version(12054)
        2021.12.12-19:31:07 (11104): GetAd Info From server success(4000).
        2021.12.12-19:31:07 (11104): GetAd Info From server success(1004).
        burn_internal (partial)
        =================================== 2021-12-12 19:31:02 ====================================
        Drive informations: H:\ [PLEXTOR BDDVDRPX-B310U]
        -CanWriteCDR: 1
        -CanWriteCDRW: 1
        -CanWriteDVDR: 1
        -CanWriteDVDRAM: 1
        -CanWriteDVDRDL: 1
        -CanWriteDVDRW: 1
        -CanWriteDVDRWDL: 1
        -CanWriteDVDPlusR: 1
        -CanWriteDVDPlusRDL: 1
        -CanWriteDVDPlusRW: 1
        -CanWriteDVDPlusRWDL: 0
        -CanWriteHDDVDR: 0
        -CanWriteHDDVDRDL: 0
        -CanWriteHDDVDRW: 0
        -CanWriteHDDVDRWDL: 0
        -CanWriteHDDVDRAM: 0
        -CanWriteBDR: 0
        -CanWriteBDRE: 0
        -CanWriteBDSRM: 0
        -CanTestWrite: 1
        -CanLayerJumpRecord: 1
        -MaximumWriteSpeed: 8990
        -LoadingMechanismType: 1
        1025
        Drive informations: F:\ [PLEXTOR BDDVDRPX-B310U]
        -CanWriteCDR: 1
        -CanWriteCDRW: 1
        -CanWriteDVDR: 1
        -CanWriteDVDRAM: 1
        -CanWriteDVDRDL: 1
        -CanWriteDVDRW: 1
        -CanWriteDVDRWDL: 1
        -CanWriteHDDVDR: 0
        -CanWriteHDDVDRW: 0
        -CanWriteBDR: 0
        -CanWriteBDRE: 0
        -CanWriteBDSRM: 0
        -CanTestWrite: 1
        -MaximumWriteSpeed: 8468
        1025
        Drive informations: D:\ [HL-DT-ST DVDRAMGUE1N]
        -CanWriteCDR: 1
        -CanWriteCDRW: 1
        -CanWriteDVDR: 1
        -CanWriteDVDRAM: 1
        -CanWriteDVDRDL: 1
        -CanWriteDVDRW: 1
        -CanWriteDVDRWDL: 1
        -CanWriteHDDVDR: 0
        -CanWriteHDDVDRW: 0
        -CanWriteBDR: 0
        -CanWriteBDRE: 0
        -CanWriteBDSRM: 0
        -CanTestWrite: 1
        -MaximumWriteSpeed: 4234
        19:31:02 Info GetWriterCount: 0 - 3
          After a time, these drives simply do not read Blu-rays properly, even if cleaned periodically using one of those brush discs. Two of my outboard players will no longer read all the way through a BD-50, although they used to, and will still play through most BD-25's. I just think the alignment eventually gets a time bit out of whack, or the lens just can't get that laser through the layer changes (which is the point where two of my machines just freeze up anymore). As for the ISO files, I never use them to make copies...only physical discs.
