Help! Dvdfab keeps crashing after analyzing phase
    Try the new beta (v7.0.5.3), it has a crash fix that may help.
      Originally posted by Complication View Post
      FabCore.exe is normal. You wouldn't have seen it unless DVDFab has a hard crash.
      I did not know that. Learn something every day. Thx.
      sigpic
        Ipop - I have been ripping it to my hard drive first before burning. Also since I don't have 50GB Blu-Ray media I dont think I can use imgburn because I don't believe it can compress a full blu-ray into a 25GB disc... Unless I'm wrong...
        I still have no fix for this....
          Signals,
          I tried the new beta 7.0.5.3 and I still get the same error... I've tried reinstalling DVDFab and I still no change. Agh
            (1) It's best practice to rip onto HDD first (folder or ISO - matter of preference) and use it as a source for compression, conversion or other manipulation.
            (2) ImgBurn is a best burning engine to work with DVDFab. It doesn't have to be BD50 media, you can burn any media using ImgBurn with or without DVDFab.
            Here's guidelines how to make it happen:
            (3) You can compress your BD50 original content, and you have variety of options. You can compress BD50 to:
            (a) BD25 1080 Full Disc
            (b) BD25 Main Movie
            (c) BD9 1080p Main Movie
            (d) BD9 720p Main Movie
            (e) BD5 1080p Main Movie
            (f) BD5 720p Main Movie
            and you can burn all of them onto media using ImgBurn
            sigpic
              Ipopov,
              Thanks for your help again. I could already see those options in DVDfab. Unfortunately, I can't even get past the ripping step of DVDfab. This is my problem... Before DVDfab actually starts to rip the blu-ray it has an analyzation phase in which my software always crashed at when it gets to 100% now.
              I've tried installing an ATI Radeon driver in hopes that it was an updated version. I restarted my laptop and still same issue. It keeps crashing at the SAME exact spot on any blu-ray disc. I'm going to try to rip a DVD to see if it's just blu-rays or the whole program in general.
                You start this post with v.7.0.4.0, are still use it. You should update it (v7.0.5.3 seems have crash instances fixed);
                If you problem persist, I would suggest to start new thread under 7.0.5.3 header.
                This thread gone far to a page 3 now. Usually these long threads are useless, nobody reading whole saga, and you wouldn't get any help.
                sigpic
                  yup I agree install the latest beta and if same issue start new thread
                    I did use the new Beta 7.0.5.3. It still does the same thing. Why start a new thread on a Beta version when it's not in it's final stages. I'd rather try to figure this out on a stable version which is what I've had to revert to.
                    I guess I'll never get this fixed. Does DVDfab have tech support???
