Like CBR929 mentioned CCleaner works just fine and you have a choice to back up the registry before you delete. You only delete the ones related to DVDFab
problems with window 2000
Originally posted by gator295 View Postonly thing I found were for dvdfab passkeyIs PassKey running when you are using Fab to open the disc???
If so you have to disable passkey and let Fab open the disc
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Originally posted by gator295 View Postno the version of passkey I had expired a while ago and was uninstalled a while ago too.
It was just the only things related to DVD fab I found in the registery using that CCleaner. So Im unsure what to do now.
No luck with that though, same thing, starts to read then goes away.
same error that say reinstall
DVDFab 8.0.2.4 (2010/10/19 01:30:19)
0m 01.00s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 file2mobile 1 filemover 1
0m 06.75s: detected dvd
0m 06.82s: drive G
0m 06.82s: dvd type 1
0m 06.82s: volume label IRON_MAN_2_D1
0m 07.59s: detected dvd
0m 07.67s: drive G
0m 07.68s: dvd type 1
0m 07.68s: volume label IRON_MAN_2_D1
0m 08.67s: file is corrupt, please re-install DVDFab
2010-10-19 01:30:48 ---- ******************** Log session stop 19-Oct 01:30:48.843 PID 1420********************
2010-10-19 01:30:19 Info Current Drive selected : 1:0:0 - HL-DT-ST DVD-RAM GH22LP20 2.00 [G] (Ide)
2010-10-19 01:30:19 Info Using Patin-Couffin driver Version 1.37, Internal revision 37 Async. Access mode
2010-10-19 01:30:19 Info System default language : English (United States)
2010-10-19 01:30:19 Info User default language : English (United States)
2010-10-19 01:30:19 Info DLL Version : 4.0.11.473
2010-10-19 01:30:19 Info DLL : F:\Program Files\DVDFab 8\vso_hwe.dll
2010-10-19 01:30:19 Info Version : 8, 0, 2, 4
2010-10-19 01:30:19 Info ExeName : F:\Program Files\DVDFab 8\DVDFab.exe
2010-10-19 01:30:19 Info OS : Microsoft Windows 2000 Professional (Build 2195: Service Pack 4)
2010-10-19 01:30:19 ---- ******************** Log session start 19-Oct 01:30:19.734 PID 1420********************
Originally posted by AGJ View PostGuess will have to see what a developer says since you are using Windows 2000. This could be a problem with that OS system
wasn't it 8017 I think from the bigger thread on it here???
Any way I can get a download of that to try????
8017 is not available and is no longer supported since it has been replaced by newer versions. Have you tried installing DVDFab on your C: drive?Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
In addition to signals' comments, I doubt that 8017 will work for you anyway.
I believe this is the thread you were talking about and 8017 worked for some users, but for many it did not.
Apparently there are multiple versions of the R1 disc out there.
Here's a link:
Originally posted by signals View Post8017 is not available and is no longer supported since it has been replaced by newer versions. Have you tried installing DVDFab on your C: drive?
F is just my large drive with 70+ gigs of space, all the other drive only have a few gigs of space or less.
It should not really matter, but something on your system is causing a problem. After installing to the default location on the C: drive you can put the DVDFab temp files on the F: drive in Common Settings.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Originally posted by sfrcpilot View PostI use windows 2000 and i didnt have a bit of a problem with ironman 2 region 1
changed drive letters of the install, even tried fat32 and NTFS no change.
-Running program-
zone alarm
lightscribe CP
APC power chute
microsoft sidewinder game controller CP
logitech game controller CP
Avast free
windows 2000 pro SP4
2.93GHz Celron
1.5GB ram
Nvidia GF 6600
