I made a 4K MKV of Forrest Gump but the audio is about half a second ahead of the video. Looking for a way to correct this so it syncs up. I'll have to rip it again if you want logs I'm just seeing if Fab even offers a feature that will do this.
Does Fab offer a way to correct out of sync issues?
No, sorry, not presently. Is the audio offset linear throughout the film, i.e. same at the beginning and end? It is an unusual problem that doesnn't happen much anymore.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
I can't work with 4K without using the GPU unfortunately. It would take days.Originally posted by october262 View Postyou can try clicking common settings - AV codec - tick Disable all GPU codecs for decoding and encoding
everything will switch to software, restart dvdfab and retry making a 4K MKV again and see if that helps.
Yes. It's offset 425ms throughout the entire film. I'll try MKVToolNix but I don't know if they support 4K video. Is Fab going to support this in the future?Originally posted by signals View PostNo, sorry, not presently. Is the audio offset linear throughout the film, i.e. same at the beginning and end? It is an unusual problem that doesnn't happen much anymore.
