Does the trial mode have some limitations aside from the 3 count? I tried ripping 1 chapter from a UHD disc in hardware acceleration and one in software mode and the files resulted exactly the same. They also took the same amount of time to complete which was in hardware acceleration speed. It seems as though the software ripping didn't work. I want to be able to software rip and not use hardware acceleration because hardware acceleration doesn't compress the files as well as software compression does.
My second question is about Cinavia removal. If I purchase UHD Ripper does it already come with Cinavia removal or do I have to purchase it in addition to UHD Ripper to remove it?
